2006.06.15豁免清单
2006.06.15豁免清单
Scope of the RoHS Directive (Exemptions)
On 1 July 2006 the RoHS Directive (2002/95/EC) becomes enforceable. This Directive bans the putting on the EU market of new electrical and electronic equipment (EEE) containing more than 0.1% lead, mercury, hexavalent chromium, PBB and PBDE and 0.01% Cadmium. The RoHS Directive covers nearly all kind of EEE “designed for the use with a voltage not exceeding 1000 volts for alternating current and 1500 volts for direct current”. Medical devices as well as monitoring and control instruments are not covered by the scope of the RoHS Directive. Also the Directive does not apply to spare parts for the repair or to the reuse, of EEE put on the market before 1 July 2006. Further exemptions are only possible due to technical reasons. Until now some exemptions are made as listed below.
Exemptions in force:
1 Mercury in compact fluorescent lamps not exceeding 5 mg per lamp.
2 Mercury in straight fluorescent lamps for general purposes not exceeding.
__halophosphate 10 mg
__triphosphate with normal lifetime 5 mg
__triphosphate with long lifetime 8 mg
3 Mercury in straight fluorescent lamps for special purposes.
4 Mercury in other lamps not specifically mentioned in this Annex.
5 Lead in glass of cathode ray tubes, electronic components and fluorescent tub
6 Lead as an alloying element in steel containing up to 0,35% lead by weight,
aluminium containing up to 0,4% lead by weight
and as a copper alloy containing up to 4% lead by weight.
7 (2005/747/EG) — Lead in high melting temperature type solders (i.e. lead-based alloys containing 85 % by weight or more lead),
— lead in solders for servers, storage and storage array systems, network infrastructure equipment for switching,
signalling, transmission as well as network management for telecommunications,
— lead in electronic ceramic parts (e.g. piezoelectronic devices).
8 (2005/747/EG) Cadmium and its compounds in electrical contacts and cadmium plating except for applications banned under Directive 91/338/EEC () amending Directive 76/769/EEC (*) relating to restrictions on the marketing and use of certain dangerous substances and preparations.
9 Hexavalent chromium as an anti-corrosion of the carbon steel cooling system in absorption refrigerators.
9a (2005/717/EG) DecaBDE in polymeric applications
9b (2005/717/EG) Lead in lead-bronze bearing shells and bushes
11 (2005/747/EG) Lead used in compliant pin connector systems.
12 (2005/747/EG) Lead as a coating material for the thermal conduction module c-ring.
13 (2005/747/EG) Lead and cadmium in optical and filter glass.
14 (2005/747/EG) Lead in solders consisting of more than two elements for the connection between the pins and the package of microprocessors with a lead content of more than 80 % and less than 85 % by weight.
15 (2005/747/EG) Lead in solders to complete a viable electrical connection between semiconductor die and carrier within integrated circuit Flip Chip packages.’
16 (2006/310/EC) Lead in linear incandescent lamps with silicate coated tubes
17 (2006/310/EC) Lead halide as radiant agent in High Intensity Discharge (HID) lamps used for professional reprography applications
18 (2006/310/EC) Lead as activator in the fluorescent powder (1% lead by weight or less) of discharge lamps when used as sun tanning lamps containing phosphorus such as BSP (BaSi2O5:Pb) as well as when used as speciality lamps for diazo-printing reprography, lithography, insect traps, photochemical and curing processes containing phosphorus such as SMS ((Sr,Ba)2MgSi2O7:Pb)
19 (2006/310/EC) Lead with PbBiSn-Hg and PbInSn-Hg in specific compositions as main amalgam and with PbSn-Hg as auxiliary amalgam in very compact Energy Saving Lamps (ESL)
20 (2006/310/EC) Lead oxide in glass used for bonding front and rear substrates of flat fluorescent lamps used for Liquid Crystal Displays (LCD)
johney007 (威望:0) (上海 嘉定)
非常感谢楼主热心提供的消息。
能有中文版的最好了。
加分鼓励。
10 个回复,游客无法查看回复,更多功能请登录注册
