MINITAB中这个MSA判定准则的依据是???
If the Total Gage R&R contribution in the %Study Var column (% Tolerance, %Process) is:
· Less than 10% - the measurement system is acceptable.
· Between 10% and 30% - the measurement system is acceptable depending on the application, the cost of the measuring device, cost of repair, or other factors.
· Greater than 30% - the measurement system is unacceptable and should be improved.
If you are looking at the %Contribution column, the corresponding standards are:
· Less than 1% - the measurement system is acceptable.
· Between 1% and 9% - the measurement system is acceptable depending on the application, the cost of the measuring device, cost of repair, or other factors.
· Greater than 9% - the measurement system is unacceptable and should be improved.
蚂蚁 (威望:8) (广东 深圳) 咨询业 咨询顾问
就好像现在米买2.5元一斤,猪肉买7元一斤
一样的:D
2 个回复,游客无法查看回复,更多功能请登录注册
israel
israel
man always remember  love because of romantic only
