You can use Minitab to analyze the problem .
input you data in Minitab 14 , then go to use graph\probability plot
you can get a graph , check P value , if it is great than 0.05 , the data set should be norminal distribution. otherwise it is no-norminal data
18 个回复
Honeywell (威望:2)
赞同来自: 2102078 、AndryLee 、jack2012 、zq5131065 、faber
