第五批RoHS最新豁免指令2006年10月14日公佈
第21點:
用於硼矽玻璃瓷漆的印刷油墨所含的鉛及鎘。(Lead and cadmium in printing inks for the application of enamels on borosilicate glass.)【2006/691/EC】
第22點:
用於光纖通訊系統,以稀土鐵石榴石晶體製成的法拉第旋轉器中作為雜質的鉛。(Lead as impurity in RIG (rare earth iron garnet) Faraday rotators used for fibre optic communications systems.) 【2006/691/EC】
第23點:
小螺距零件表面材料所含的鉛。(Lead in finishes of fine pitch components other than connectors with a pitch of 0.65 mm or less with NiFe lead frames and lead in finishes of fine pitch components other than connectors with a pitch of 0.65 mm or less with copper lead frames.)【2006/691/EC】
第24點:
通孔盤狀及平面陣列陶瓷多層電容器焊料所含的鉛。(Lead in solders for the soldering to machined through hole discoidal and planar array ceramic multilayer capacitors.)【2006/691/EC】
第25點:
等離子
jolly_yqh (威望:0) (广东 ) 电子制造 主管 - 体系
jolly-yqh#163.com
谢谢
68 个回复,游客无法查看回复,更多功能请登录注册
