塑胶件打螺丝,电批扭力设定求助
请问PBT-GE VALOX 760的料, M4的自攻螺丝, 塑胶件孔径3.4mm, 电批扭力要设定多大呢? 3.5Nm合适吗?
waywang2006 (威望:6) (广东 深圳) 咨询业 高级讲师、项目经理 - Oway/ 冬瓜茶20年质量管理经验,中质协注册...
General values for inox screws according to Class 6, 9 – DIN 931, 933
Screw Torque Tolerance
M2 0.3 Nm 25%
M2.5 0.6 Nm
M3 1.05 Nm
M4 2.40 Nm
M5 4.73 Nm
M6 8.13 Nm
Each screw (unless explicitly mentioned otherwise in the Work instruction) MUST be tightened with the concerned torque according to its screw thread dimensions.
请注意单位是Nm,如果换算成Kgfcm则应乘10倍。因为1Nm=10Kgfcm
20 个回复,游客无法查看回复,更多功能请登录注册
red1ion
red1ion
努力工作,努力提高,努力赚钱!
