二、欧盟将更新RoHS指令豁免物质清单
近期,欧盟将对RoHS指令的豁免清单进行再次更新,并把2005年9月2日至10月28日确立为征求意见期。虽然这些豁免项目没有最终确立下来,不能算是欧盟的正式决议,但豁免清单对企业还是有很强的参考意义。
1.Linear incandescent lamp(线型白炽灯);
2. Mercury in switches(开关中的汞);
3.Special ICs having tin-lead solder plating on leads used in professional equipment(专业设备中所含镀有铅锡焊料的铅的特殊集成电路)
4.Specific modular units including tin-lead solder being used in special professional equipment(特殊专业设备中包含铅锡焊料的特定组合单元);
5.Solders containing lead and /or cadmium for specific applications where local temperature is higher than 150 deg C and which need to work properly more than 500 hours(局部温度超过150℃且需要正常工作500小时以上的特定用途的含有铅和/或镉的焊料);
6.Lead in solder for printed circuit boards for emergency lighting products(应急照明产品中印刷电路板所用焊料中的铅
7.Hexavalent chromium (Cr-VI) in chromate conversion coatings as surface treatment(表面处理用铬酸盐转化涂层中的六价铬);
8.Lead in gas sensors(烟雾探测器中的铅);
9.Concerning of PbO (Lead in Seal Frit) used for making BLU (Back Light Unit) Lamp(与用于制造背景灯的PbO(密封釉料中的铅)相关的);
10. Cadmium in opto-electronic components(光电元件中的镉);
11. Non-consumer mechanical power transmission systems including speed reducers and mechanical couplings which rely on electrical/electronic components for safe control and operation(依靠电子/电器元件来进行安全控制和操作的减速器和机械连接器等非消费型机械式能量传递系统);
12. Electrical and electronic components contained in heating ventilating and air conditioning building systems, commercial refrigeration systems and transport refrigeration systems(加热通风和空调建筑系统、商用冷却系统和运输冷却系统中的电子和电器元件);
13. Cadmium-bearing copper alloys(含镉的铜合金);
14. Electrical/electronic components contained mobile and stationary air compressors and vacuum systems, compressed air contaminant removal systems and pneumatic contractor’s air tools(含有电子/电器元件的移动和固定空气压缩机和真空系统、压缩气体污染物清除系统和气动压缩机的气体工具);
15. Electrical/electronic equipment that are: used in transport -aviation, aerospace, road, maritime, rail; installed in to the fabric of buildings ? elevators, escalators, moving walks, dumb waiters, and heating, cooling and ventilation systems, and fire and security systems; used in the energy generation and transmission; used in mining and mineral processing; used for non-consumer mechanical power transmission systems; industrial process pumps and compressors; used in industrial refrigeration; and used in military applications(以下电子/电气设备:航运、航天、道路、海运、铁路中使用的;建筑物构造??电梯、电动扶梯、移动走道、小型运货升降机、加热、冷却和通风系统、防火安全系统中安装的;能量产生和传输中使用的;采矿和矿石加工中使用的;非消费型机械式能量传递系统中使用的;工业作用泵和压缩机;工业制冷用的;军事设备中使用的);
1 6. Lead alloys as electrical/mechanical solder for transducers used in high-powered professional and commercial loudspeakers(大功率专业用和商用扩音器中的传感器中作为电气/机械焊料的铅合金);
17. Cadmium oxide(氧化镉);
18. Solder tin of the thermo fuse with a defined low melting point(有固定低熔点的温度保险丝中的锡焊料);
19. Lead in lead oxide glass used in plasma display panel (PDP)(氧化铅玻璃等离子显示器面板中使用的铅);
20. Lead in solder on small PCB and tinned legs of primary components(小型印刷电路板和初级元件的镀锡引线所用焊料中的铅);
21. Use of the not lead free component NEC V25 in the Memory 2000(2000年备忘录中非无铅元件NEC V25的使用);
22. Lead used in shielding of radiation for Non Medical X-ray equipment(非医用X光机的射线防护屏中使用的铅);
23. Lead based solders sealed or captured within heat-shrinkable components and devices(热收缩性元件和设备中密封或俘获的铅基焊料).
3 个回复
wangry (威望:2) (江苏 无锡) 机械制造 经理 - 热心助人。
一、欧盟将阻燃剂十溴二苯醚列入 RoHS 指令豁免清单
欧盟委员会于2005年10月15日在其官方通讯上做出的决议中,将十溴二苯醚列入《电子电气设备中限用有害物质指令》(RoHS 指令)的豁免清单。欧盟委员会在对所有可用信息进行仔细评估之后,做出了此决议。
欧洲溴化阻燃剂行业委员会(EBFRIP)对这一欧盟决议表示非常欢迎,该决议立即生效并将对十溴二苯醚的继续使用产生深远的影响。十溴二苯醚是一种非常高效的阻燃剂,用于阻止电子电器设备的塑料组件燃烧和减缓火灾蔓延速度,从而挽救生命和减少火灾造成的伤亡。同时该产品也被广泛用于纺织和交通行业。
决议原文:http://europa.eu.int/eur-lex/l ... 0.pdf
二、欧盟将更新RoHS指令豁免物质清单
