汽车内饰材料的试验标准
1.耐清洁性——Cleanability GM 9900P
GM 9126P
GMW 3402
FLTM BN 107-01
2.耐磨损性——Abrasion GM 3208A (Taber)
GM 3208B (Taber)
ASTM D3884 (Taber)
DIN EN ISO12947(Martindale)
3.气味性——Odor SAE J1351
GM 9130P
PV 3900
GME 60276
FLTM BO 131-01
MS 300-34
EDS-T-7603(A、B、C类)
4.拉伸强力——Tensile Strength ASTM D5034
ASTM D5035
DIN EN ISO 12947
5.撕破强力(a)——Tearing Strengt ASTMD5587(梯形)
ASTMD2261(单舌)
DIN 53356
6.剥离强力——Bond Strength ASTM D751
DIN 53357
7.接缝强力——Seam Strength GM 9129P
8.静态和永久伸长——Static and Permanent Elongation PV 3909
9.拒油性——Oil Repellency AATCC ll8
10.阻燃性——Flammability GM 9070P
ISO 3795
GB 8410
MS 300—08
FMVSS 302
UL 94
GMW 3232
11.耐刮伤性——Marring & Scuffing GM 9150P
12.透气性——Air Permeability GB/T 5453
ISO 9237
13.防霉性——Resistance to Mildew GM 9128P(14天)
14.尺寸稳定性——Dimensional Stability SAE J883
GM 9452P
GM 9452P & GM 9505
15.水解稳定性——Hydrolic Stabilit GM 9231P(168小时)
16.排水性——Water Repellency GM 9317P
17.柔韧性——Pliability GM 9664P
18.抗起球性——Resistance to Pilling GM 3347P
ASTM D3512
GM 9652P
ASTM D4970
19.耐水斑、盐渍性——Water Spotting,Salt GM 9133P
20.耐汗渍色牢度——Colorfastness to Perspiration FLTM BI 113-06
22.抗汗性——Resistance to Perspiration GM 9240P
23.耐水色牢度——Dye Stability AATCC 107
24.耐摩擦色牢度——Colorfastness to Rubbing AATCC 8
FLTM BN 107-01
25.拉伸回复性能——Recoverability SAE J855
26.SO2点蚀法——Resistance to SO2 GM 9736P
27.有机化合物挥发(苯、甲苯、二甲苯等)——Benzene、Methylbenzene、Xylene,etc.
Head-Space-GC/MS
28.总碳挥发——VOC PV 3341
TS INT 20
29.甲醛含量——Formaldehyde Content PV 3925
GME 60271
30.重金属含量——Heavy Metal GB/F l7593(游离量)
31.重金属含量(总量法Pb Hg Cd)——Heavy Metal (Total Method)
EPA 3050B(产品为塑料件/及其涂层)
32.六价铬——Cr6+ GB 7467
33.氙弧加速老化及耐光色牢度——Acceleration Aging(Xenon Lamp) & Colorfastness to light
SAE J1885
SAE J1960
GMW 3414
PV 3902
34.纤维降解——Fiber Degradation GM 9771P
35.循环老化——Cycle Aging GM 9200P
36.雾化——Fogging SAE J 1756
37.低温/高湿(气候试验)——Low Temperature/Humidity
38.普通烘箱(常温))——Oven
以上可能存在笔误,请业内专家指正和补充.不胜感谢!
GM 9126P
GMW 3402
FLTM BN 107-01
GM 3208B (Taber)
ASTM D3884 (Taber)
GM 9130P
PV 3900
GME 60276
FLTM BO 131-01
MS 300-34
EDS-T-7603(A、B、C类)
ASTM D5035
DIN EN ISO 12947
ASTMD2261(单舌)
DIN 53356
DIN 53357
ISO 3795
GB 8410
MS 300—08
FMVSS 302
UL 94
GMW 3232
ISO 9237
GM 9452P
GM 9452P & GM 9505
ASTM D3512
GM 9652P
ASTM D4970
FLTM BN 107-01
Head-Space-GC/MS
TS INT 20
GME 60271
SAE J1885
SAE J1960
GMW 3414
PV 3902
38.普通烘箱(常温))——Oven
10 个回复
xqhu01 (威望:0) (湖北 荆州) 机械制造
