机械设计名词英文术语
calculated bending moment 计算弯矩
cam 凸轮
cam , cam mechanism 凸轮机构
cam profile 实际廓线
cam profile 凸轮廓线
cam with oscillating follower 摆动从动件凸轮机构
cantilever beam 悬臂梁
cantilever structure 悬臂结构
Cartesian coordinate manipulator 直角坐标操作器
cascade speed control 串级调速
case-based design,CBD 基于实例设计
center distance 中心距
center distance change 中心距变动
center of mass 质心
center of pressure 压力中心
central gear 中心轮
centrifugal force 离心力
centrifugal force 向心力
centrifugal seal 离心密封
centrifugal stress 离心应力
chain 链
chain dotted line 点划线
chain gearing 链传动装置
chamfer 倒角
change gear ; change wheel 变速齿轮
characteristics 特性
chassis 底座
circular gear 圆形齿轮
circular pitch 齿距
circular pitch; pitch of teeth 节距
circular thickness 圆弧齿厚
circulating power load 循环功率流
clearance 径向间隙
clockwise 顺时针
closed chain mechanism 闭链机构
closed kinematic chain 闭式链
clutch 离合器
coarse thread 粗牙螺纹
coefficient of friction 摩擦系数
coefficient of speed fluctuation 机械运转不均匀系数
coefficient of speed fluctuation 速度不均匀( 波动 ) 系数
coefficient of travel speed variation 行程速度变化系数
coefficient of velocity fluctuation 运转不均匀系数
coincident points 重合点
combination in parallel 并联式组合
combination in series 串联式组合
combined efficiency; overall efficiency 总效率
combined mechanism 组合机构
combined stress 复合应力
common apex of cone 锥顶
common normal line 公法线
compensation 补偿
complex mechanism 复杂机构
composite tooth form 组合齿形
compound (or combined) gear train 复合轮系
compound combining 复合式组合
compound flat belt 复合平带
compound gear train 混合轮系
compound hinge 复合铰链
Compound screw mechanism 复式螺旋机构
compression strength 抗压强度
compressive stress 压应力
compressor 压缩机
computer aided design, CAD 计算机辅助设计
computer aided manufacturing, CAM 计算机辅助制造
computer integrated manufacturing system, CIMS 计算机集成制造系统
concavity 凹面、凹度
concept design, CD 方案设计、概念设计
concurred design, CD 并行设计
concurrent engineering 并行工程
condition of self-locking 自锁条件
conduction of heat 导热性
cone angle 圆锥角
cone distance 锥距
conjugate cam 共轭凸轮
conjugate profiles 共轭齿廓
conjugate yoke radial cam 等径凸轮
connecting rod, coupler 连杆
conoid helical-coil compression spring 圆锥螺旋扭转弹簧
constant-breadth cam 等宽凸轮
constant-velocity (or double) universal joint 双万向联轴节
constitution of mechanism 机构组成
constraining force 约束反力
constraint 约束
constraint condition 约束条件
consumption 消耗
contact points 啮合点
contact ratio 重合度
contact seal 接触式密封
contact stress 接触应力
conventional mechanism; mechanism in common use 常用机构
convex 凸的,凸面体
convex roller 球面滚子
coordinate frame 坐标系
correcting plane 平衡平面
correcting plane 校正平面
corrosion resistance 耐腐蚀性
cosine acceleration (or simple harmonic) motion 余弦加速度运动
counterclockwise (or anticlockwise) 逆时针
counterweight 平衡重
couple 力偶
coupler-curve 连杆曲线
coupling ; shaft coupling 联轴器
crank 曲柄
crank angle between extreme (or limiting) positions 极位夹角
crank arm, planet carrier 系杆
crank shaft 曲轴
crank shaper (guide-bar) mechanism 曲柄导杆机构
crank-rocker mechanism 曲柄摇杆机构
creation design 创新设计
critical speed 临界转速
cross-belt drive 交叉带传动
crossed helical gears 交错轴斜齿轮
cro[/c
cam 凸轮
cam profile 实际廓线
cam profile 凸轮廓线
cantilever beam 悬臂梁
center distance 中心距
center of mass 质心
central gear 中心轮
chain 链
chain gearing 链传动装置
chamfer 倒角
characteristics 特性
chassis 底座
circular gear 圆形齿轮
circular pitch 齿距
clearance 径向间隙
clockwise 顺时针
clutch 离合器
coarse thread 粗牙螺纹
compensation 补偿
compound hinge 复合铰链
compressor 压缩机
concavity 凹面、凹度
cone angle 圆锥角
cone distance 锥距
conjugate cam 共轭凸轮
constraint 约束
consumption 消耗
contact points 啮合点
contact ratio 重合度
contact seal 接触式密封
contact stress 接触应力
convex 凸的,凸面体
convex roller 球面滚子
counterweight 平衡重
couple 力偶
coupler-curve 连杆曲线
crank 曲柄
crank shaft 曲轴
critical speed 临界转速
cro[/c
stormlu (威望:0) (广东 深圳) 家电或电器 经理
