公司英语 (产品)
二、产品: {V{V{V
连接器connector
端子terminal
条型连接器bar connector
阴连接器Housing
阳连接器wafer
线束wire harness
间距space
额定电压 rated voltage
额定电流 rated current
接触电阻contact resistance
绝缘电阻insulation resistance
超声波焊接ultrasonic welding
耐压withstand voltage
针pin
物料编号part number
导线wire
基体金属Base metal
电缆夹cable clamp
倒角chamfer
接触面积contact area
接触件安装孔contact cavity
接触长度contact length
接触件电镀层contact plating
接触压力contact pressure
接触件中心距contact space
接触簧片contact spring
插孔socket contact
法兰、凸缘Flange
界面间隙interfacial gap
键Key
键槽keyway
过渡段ramp
屏蔽套shielding
定位基准Datum reference
扁平电缆flat cable ,Ribbon cable
柔性印刷电线Flexible printed wiring
多层印制电路Multilayer printed circuit
焊盘pad
图形pattern
间距pitch
负极Negative pole
正极positive pole
回流Reflow
原理图Schematic diagram
单面板single sided board
双面板Two-sided board,Double-sided board
表面安装surface Mounting
翘曲warp, bow
波峰焊wave soldering
编织层braid
同轴电缆coaxial cable
电介质dielectric
电缆中导线的头数ends
外部干扰external interference
填充物filler
护套jacket
比重specific gravity
电阻的温度系数Temperature coefficient of resistance
owenyu (威望:0) (江苏 南京) - 中國江蘇
Thanks for you show
19 个回复,游客无法查看回复,更多功能请登录注册
stephenSun
stephenSun
Nothing is impossible.
