[原创]Binomial
Estimating a Defect Rate From a Sample
Voting Polls
Of 1000 voters sampled, 600 indicated that they were going to vote for Candidate A.
· How would you estimate the proportion of voters who will vote for Candidate A in the real election?
· How confident would you be that Candidate A will win the election?
To estimate a true process defect rate or a true process yield simply use the sample data:
or,
Exercises on Estimating
True Process Defect Rates
and True Process Yields
Defect Data Exercise:
If 27 defective units were found in a sample of size 13,000, provide an estimate of the true process defect rate:
Yield Data Exercise:
If 1163 good units were found in a sample of size 1165, provide an estimated of the true process yield:
How confident are you that these estimates are close to the true values? The next topic concerns placing confidence intervals around the estimates.
Two-Sided Confidence Intervals for Means
For most of the cases involving continuous data in DOE I, a two-sided confidence interval would be placed around the sample mean (the estimate of the true process mean).
The required information to construct the confidence interval included:
Continuous Data Example:
= 10
s = 2
n = 30
The 95% confidence interval is .
This is called a “two-sided” confidence interval, since the mean is bounded on two sides. The confidence interval contains both a lower bound (9.28 for this example) and an upper bound (10.72 for this example).
Interpretation: We are 95% confident that our confidence interval of has captured the true process mean.
One-sided Confidence Intervals for Proportions
For most of the cases involving proportional data, a one-sided confidence interval should be placed around the sample proportion.
Defect Data Example:
15 defective units were found in 300 units randomly collected from a process:
sample defect rate = (15/300) = 5%
This is called a “one-sided” confidence interval.
Interpretation: We are 95% confident that the confidence interval has captured the true process defect rate.
For defect data, the lower bound is usually set to 0%, and only an upper bound is calculated and reported.
One-sided Confidence Intervals Continued
Yield Data Example:
1200 units were processed, and all 1200 units tested “good”.
sample yield = (1200/1200) = 100%
95% confidence interval =
Interpretation: We are 95% confident that the confidence interval has captured the true process yield.
For yield data, the upper bound is usually set to 100%, and only a lower bound is calculated and reported.
BKM for Using Binomial Methods versus Using Continuous Methods for 1-sample Defect Data or Yield Data
BKM for Using Binomial Methods versus Using Continuous Methods for 2-sample Defect Data or Yield Data GD
Voting Polls
or,
- sample mean
- sample standard deviation
- sample size
= 10
s = 2
n = 30
Yield Data Example:
jpzhang (威望:0) (广东 广州) 纺织业 经理
