Minitab动画教程
标准差估计方法采用Minitab选用的“合并标准差”,该方法计算出来的西格玛更严格,但相应的Cpk值将会降低(感谢QQ里的Minitab学习群里的“树上右从”兄无私的解答,When the subgroup size is greater than 1, Minitab uses the Pooled standard deviation over the Rbar method for estimating the standard deviation because the relative efficiency of using the range instead of the pooled standard deviation decreases as the subgroup size increases (the range uses only the minimum and maximum values in the subgroup, and the standard deviation uses all of the data). The relative efficiency of the range method compared to s (the sample standard deviation) is shown here for various sample sizs: n Relative Efficiency
2 1.000
3 0.992
4 0.975
5 0.955
6 0.930
10 0.850
From Montgomery 2005, 95-96.
Montgomery 2005, 95 states, "Using the range to estimate dates from the earliest days of statistical quality control, and it was popular because it is very simple to calculate. With modern calculators and computers, this isn't a major consideration today. Generally, the "quadratic estimator" based on s is preferable."
Reference: D.C. Montgomery (2005). Introduction to Statistical Quality Control, Fifth Edition. John Wiley & Sons, Inc.)
同时,增加了新增子组数据时,Xbar-R自动更新功能的演示。
如各位同仁有不同意见,可以在回帖中指出,大家共同学习。
请使用另存下载,每下载一个资料扣5个6SQ币! 如何获得6SQ币? 点击查看
本站下载内容均为网友上传,如果涉及侵犯您的版权或违法内容,请联系我们立即删除
尽自己的力量,对“好”的回答一定要点个"赞"
life0650
楼主,我下载不了啊,是否可以转发至个人邮箱。
LD0257@sina.com
44 个回复,游客无法查看回复,更多功能请登录注册
