TS不符合项怎么整改?
1.The following nonconformity requires corrective/preventive/improvement actions:
下述不符合事实需要采取纠正/预防/改进措施
Non-conformance Description: 不符合描述
Management system failed ensure take action to eliminate the cause of non-conformity to order to prevent recurrence.
管理系统不能确保对不符合针对问题发生的根本进行纠正以防止再发生
Objective Evidence: 客观证据
For NC raised from internal audit on 2007/12, RCA was not located that could not correct and prevent recurrence.
如在2007年12月内审中对于不符合的整改,原因这对相关要求不理解----没有分析到根本
2The following nonconformity requires corrective/preventive/improvement actions:
System failed ensure measurement and monitoring system in good status that meet needs to provide evidence of conformity of product to determined requirements
系统不能确保监视与测量装置处于良好状态以使量测系统满足得出正确测量结果的要求
Pull force tester used for text terminal crimping force, the device used for clamping terminal has wore up that could not hold the terminal, instead a pliers used for hold the terminal that caused unsure test result.
如在检验打端子压力的测试机,用于夹紧端子的装置已过度磨损以至于不能夹住端子,测量时只能用钳子夹住导致测量结果可能偏差
gb62566212 (威望:1) (江苏 苏州) 机械制造 质量和制程经理
  1. Management system failed ensure take action to eliminate the cause of non-conformity to order to prevent recurrence.
g8 q& t% a; D4 k" a7 m管理系统不能确保对不符合针对问题发生的根本进行纠正以防止再发生
审核员的英文水平太差,语法错误。呵呵。
  1. Objective Evidence: 客观证据
0 c1 p' d& a3 Y0 X) _For NC raised from internal audit on 2007/12, RCA was not located that could not correct and prevent recurrence.
0 K T5 W' g8 C0 C' w( |; `如在2007年12月内审中对于不符合的整改,原因这对相关要求不理解----没有分析到根本
审核员给的客观证据不具体,让人看不明白。
能否给出具体证据,大家好分析。
  1. 二楼的说-----第二条的改进就是对设备进行维修了,把维修的证据和维修后验证的证据给他们就可以了。那如何保证以后不会再出现类似问题“用于夹紧端子的装置已过度磨损以至于不能夹住端子”,应该有防止再发生的措施,如定期检查等。
4 个回复,游客无法查看回复,更多功能请登录注册
