calc menu of minitab
If there are 15 rows in the C2 of worksheet. I want to sum the 15 rows in the C2 column. If I use the calculator,
what i fill in the "store result in the variable",Expression,functions"
Thanks!
kevinyjy (威望:4) - 7+ years of QM experienc...
Hehe, you can do it in two ways:
  1. enter the target column into it: for example, you can enter "C3" as the taget column to enter the results; the results will be saved in "C3"
  2. enter a constant name for this variable: for example, you can enter Sum and Minitab will automatically generate a column named "Sum" after "C2" (not necessarily beside "C2")
Hope it helps you. Besides, you can use help which explains it in detail.
