Tooling management process
请问:针对校验设备和生产设备的故障维修,一般体系中都定义需进行产品追溯,但对于生产过程中使用的工具故障,是否也需如此定义呢?
CHNsea (威望:2) (北京 )
Regarding tooling.You also need a maintenance procedure to specify maintenance interval and have a record to record who perform this task at when.whether need to trace failure of toolings depend on the importance of your toolings.if the tooling is a key tooling impacting whole manufacture process, it's better to record failures.if not, you just need make records when you do maintenance in accordance with procedure.
3 个回复,游客无法查看回复,更多功能请登录注册
hellen
hellen
摄影
