Download Minitab 14
Minitab 14 is now available. Why don't you update your version to r14?
Download Minitab14:
http://w2.e-academy.com/downlo ... o.exe
It's a trial version, however, crack file is available. With this crack file, you can use the software without any restrictions. You can download the crack here:
http://www.acad.polyu.edu.hk/~ ... 4.zip
Install mtb1410e30_demo.exe first.
After installing, unzip Mtb14.zip. You should find a file called "Mtb14.exe"
Replace Mtb14.exe in the directory where you install Minitab 14 with this Mtb.exe
Then, you have done.;X.
(威望:)
精华!
27 个回复,游客无法查看回复,更多功能请登录注册
