TS16949和ISO9000在条文(条款)上的区别
首先,ISO9000是TS16949的基础。TS16949是依附于ISO9000的,从某种意义上讲,如果没有ISO9000,就没有TS16949。
其次,TS16949在ISO9000基础上补充了12条条款,内容如下:
4.1.1 General requirements - Supplemental总要求-补充
Ensuring control over outsourced processes shall not absolve the organization to the responsibility of conformity to all customer requirements.
确保控制外包过程不能免除组织对符合顾客所有要求的职责。
5.4.1.1 Quality objectives - Supplemental质量目标-补充
Top management shall define quality objectives and measurements that shall be included in the business plan and used to deploy the quality policy.
最高管理者必须规定质量目标和测量方法,质量目标和测量方法必须包括在业务计划中,并用于展开质量方针。
5.6.2.1 Review input - Supplemental评审输入-补充
Input to management review shall include an analysis of actual and potential field failures and their impact on quality, safety, or the environment.
管理评审的输入必须包括对实际的和潜在的现场失效及其对质量、安全或环境的影响的分析。
7.1.1 Planning of product realization - Supplemental产品实现的策划-补充
Customer requirements and references to its technical specifications shall be included in the planning of product realization as a component of the quality plan.
作为质量计划的一部分,顾客要求和引用的顾客技术规范必须包括在产品实现的策划中。
7.2.1.1 Customer designated special characteristics顾客指定的特殊特性
The organization shall demonstrate conformity to customer requirements for designation, documentation and control of special characteristics.
组织必须证明在特殊特性的确定、文件化和控制方面符合顾客要求。
7.2.3.1 Customer communication - Supplemental顾客沟通-补充
The organization shall have the ability to communicate necessary information, including data, in a customer-specified language and format (e.g. computer aided design data, electronic data exchange).
组织必须具有按照顾客规定的语言和格式传递必要的信息,包括数据的能力(例如:计算机辅助设计数据,电子数据交换)。
7.3.3.1 Product design outputs - Supplemental产品设计输出-补充
The product design output shall be expressed in terms that can be verified and validated against product design input requirements. The product design output shall include
产品设计输出必须以能够对照产品设计输入要求进行验证和确认的形式来表达。
7.3.6.1 Design and development validation -Supplemental设计和开发确认-补充
Design and development validation shall be performed in accordance with customer requirements including programme timing.
设计和开发确认必须按照顾客的要求包括时间进度进行。
7.5.2.1 Validation of processes for production and service provision – Supplemental生产和服务提供过程的确认-补充
The requirements of 7.5.2 shall apply to all processes for production and service provision.
7.5.2的要求必须适用于所有生产和服务提供过程。
7.5.3.1 Identification and traceability - Supplemental标识和可追溯性-补充
The words "Where appropriate" in 7.5.3 shall not apply.
条款7.5.3中的“适当时”不适用于本技术规范。
8.2.1.1 Customer satisfaction - Supplemental顾客满意-补充
Customer satisfaction with the organization shall be monitored through continual evaluation of performance of the realization processes. Performance indicators shall be based on objective data and include, but not be limited to:
组织的顾客满意必须通过持续评价实现过程的性能进行监控。
8.3.1 Control of nonconforming product - Supplemental不合格品控制-补充
Product with unidentified or suspect status shall be classified as nonconforming product (see 7.5.3).
未经确认的或可疑状态的产品必须按不合格品对待(参见7.5.3)。
5 个回复
fanrenge2000
