电池的ROHS标准和限值
Council Directive 91/157/EEC of 18 March 1991 on batteries and accumulators containing certain
dangerous substances
Official Journal L 078 , 26/03/1991 P. 0038 - 0041
Finnish special edition: Chapter 15 Volume 10 P. 0072
Swedish special edition: Chapter 15 Volume 10 P. 0072
CONSLEG - 76L0769 - 31/12/1994 - 71 P.
COUNCIL DIRECTIVE of 18 March 1991 on batteries and accumulators containing certain dangerous
substances (91/157/EEC)
THE COUNCIL OF THE EUROPEAN COMMUNITIES,
Having regard to the Treaty establishing the European Economic Community, and in particular Article
100a thereof,
Having regard to the proposal from the Commission (1),
In cooperation with the European Parliament (2),
Having regard to the opinion of the Economic and Social Committee (3),
Whereas any disparity between the laws or administrative measures adopted by the Member States on
the disposal of batteries and accumulators could create barriers to trade and distort competition in the
Community and may thereby have a direct impact on the establishment and functioning of the internal
market; whereas it therefore appears necessary to approximate the laws in the field;
Whereas Article 2 (2) of Council Directive 75/442/EEC of 15 July 1975 on waste (4), as amended by
Directive 91/156/EEC (5), provides that specific rules for particular instances or supplementing those of
the said Directive in order to regulate the management of particular categories of waste shall be laid down
by means of individual Directives;
Whereas the objectives and principles of the Community's environment policy, as set out in the European
Community action programmes on the environment on the basis of the principles enshrined in Article 130r
(1) and (2) of the EEC Treaty, aim in particular at preventing, reducing and as far as possible eliminating
pollution and ensuring sound management of raw materials resources, on the basis also of the 'polluter
pays' principle;
Whereas, in order to achieve these objectives, the marketing of certain batteries and accumulators should
be prohibited, in view of the amount of dangerous substances they contain;
Whereas, to ensure that spent batteries and accumulators are recovered and disposed of in a controlled
manner, Member States must take measures to ensure that they are marked and collected separately;
Whereas collection and recycling of spent batteries and accumulators can help avoid unnecessary use of
raw materials;
Whereas appliances containing non-removable batteries or accumulators may represent an
environmental hazard when they are disposed of; whereas Member States should therefore take
appropriate measures;
Whereas programmes should be set up in the Member States to achieve the various objectives set out
above; whereas the Commission should be informed of these programmes and of the specific measures
taken;
Whereas recourse to economic instruments such as the setting up of a deposit system may encourage
the separate collection and recycling of spent batteries and accumulators;
Whereas provision should be made for consumer information in this field;
Whereas provision should be made for appropriate procedures to implement the provisions of this
Directive, particularly the making system, and to ensure that the Directive can be easily adapted to
scientific and technical progress; whereas the committee referred to in Article 18 of Directive 75/442/EEC
should be instructed to assist the Commission in these tasks,
HAS ADOPTED THIS DIRECTIVE:
Article 1
The aim of this Directive is to approximate the laws of the Member States on the recovery and controlled
disposal of those spent batteries and accumulators containing dangerous substances in accordance with
Annex I.
Article 2
For the purposes of this Directive:
(a) 'battery or accumulator' means a source of electrical energy generated by direct conversion of
chemical energy and consisting of one or more primary (non-rechargeable) batteries or secondary
(rechargeable) cells, as listed in Annex I;
(b) 'spent battery or accumulator' means a battery or accumulator which is not re-usable and is intended
for recovery or disposal;
(c) 'disposal' means any operation, provided that it is applicable to batteries and accumulators, included in
Annex II A to Directive 75/442/EEC;
(d) 'recovery' means any operation, provided that it is applicable to batteries and accumulators, included
in Annex II B to Directive 75/442/EEC;
(e) 'collection' means the gathering, sorting and/or grouping together of spent batteries and accumulators;
(f) 'deposit system' means a system under which the buyer, upon purchase of batteries or accumulators,
pays the seller a sum of money which is refunded when the spent batteries or accumulators are returned.
Article 3
above 50° C, exposed to shocks) containing more than 0,05 % of mercury by weight,
prohibition.
restrictions on the marketing and use of certain dangerous substances and preparations (6), as last
amended by Directive 85/610/EEC (7).
Article 4
disposal.
The marking must include indications as to the following points:
the European Communities.
Article 5
Member States shall take measures to ensure that batteries and accumulators cannot be incorporated
into appliances unless they can be readily removed, when spent, by the consumer.
These measures shall enter into force on 1 January 1994.
This Article shall not apply to the categories of appliance included in Annex II.
Article 6
Member States shall draw up programmes in order to achieve the following objectives:
communicated to the Commission by 17 September 1992 at the latest.
The programmes shall be reviewed and updated regularly, at least every four years, in the light in
particular of technical progress and of the economic and environmental situation. Amended programmes
shall be communicated to the Commission in good time.
Article 7
economic instruments in order to encourage recycling. These measures must be introduced after
consultation with the parties concerned, be based on valid ecological and economic criteria and avoid
distortions of competition.
Article 8
In the context of the programmes referred to in Article 6, Member States shall take the necessary steps to
ensure that consumers are fully informed of:
(a) the dangers of uncontrolled disposal of spent batteries and accumulators;
(b) the marking of batteries, accumulators and appliances with permanently incorporated batteries and
accumulators;
(c) the method of removing batteries and accumulators which are permanently incorporated into
appliances.
Article 9
Member States may not impede, prohibit or restrict the marketing of batteries and accumulators covered
by this Directive and conforming to the provisions laid down herein.
Article 10
The Commission shall adapt Articles 3, 4 and 5 and Annexes I and II to technical progress in accordance
with the procedure laid down in Article 18 of Directive 75/442/EEC.
Article 11
thereof.
Article 12
This Directive is addressed to the Member States.
Done at Brussels, 18 March 1991.
For the Council
The President
A. BODRY
(1) OJ No C 6, 7. 1. 1989, p. 3 and OJ No C 11, 17. 1. 1990, p. 6.
(2) OJ No C 158, 26. 6. 1989, p. 209 and OJ No C 19, 28. 1. 1991.
(3) OJ No C 194, 31. 7. 1989, p. 21.
(4) OJ No L 194, 25. 7. 1975, p. 47.
(5) See page 32 of this Official Journal.
(6) OJ No L 262, 27. 9. 1976, p. 201.
(7) OJ No L 375, 31. 12. 1985, p. 1.
ANNEX I
BATTERIES AND ACCUMULATORS COVERED BY THE DIRECTIVE
ANNEX II
LIST OF CATEGORIES OF APPLIANCE EXCLUDED FROM THE SCOPE OF ARTICLE 5
and data functions of information technology and business equipment, where use of the batteries and
accumulators referred to in Annex I is technically necessary.
functioning is essential and the batteries and accumulators can be removed only by qualified personnel.
for use in highly sensitive surroundings, for example in the presence of volatile substances.
Those appliances the batteries and accumulators of which cannot be readily replaced by the user, in
accordance with this Annex, shall be accompanied by instructions informing the user of the content of
environmentally hazardous batteries and accumulators and showing how they can be removed safely.
100a thereof,
pays' principle;
raw materials;
taken;
Article 1
Annex I.
Article 2
Article 3
- Member States shall prohibit, as from 1 January 1993, the marketing of:
- all other alkaline manganese batteries containing more than 0,025 % of mercury by weight.
prohibition.
- Paragraph 1 shall be inserted in Annex I to Council Directive 76/769/EEC of 27 July 1976 on the
Article 4
- In the context of the programmes referred to in Article 6, Member States shall take appropriate steps to
disposal.
- To this end, Member States shall ensure that batteries and accumulators and, where appropriate,
- separate collection,
- where appropriate, recycling,
- the heavy-metal content.
- The Commission shall draw up, in accordance with the procedure referred to in Article 10, the detailed
Article 5
Article 6
- reduction of the heavy-metal content of batteries and accumulators,
- promotion of marketing of batteries and accumulators containing smaller quantities of dangerous
- gradual reduction, in household waste, of spent batteries and accumulators covered by Annex I,
- promotion of research aimed at reducing the dangerous-substance content and favouring the use of less
- separate disposal of spent batteries and accumulators covered by Annex I.
Article 7
- Member States shall ensure the efficient organization of separate collection and, where appropriate,
- When notifying the programmes to which Article 6 refers, Member States shall inform the Commission
Article 8
accumulators;
appliances.
Article 9
Article 10
Article 11
- Member States shall take the measures necessary to comply with this Directive before 18 September
- They shall forthwith inform the Commission thereof.
- Member States shall communicate to the Commission the texts of the provisions of national law which
thereof.
Article 12
For the Council
The President
A. BODRY
ANNEX I
- Batteries and accumulators put on the market as from the date laid down in Article 11 (1) and
- more than 25 mg mercury per cell, except alkaline manganese batteries,
- more than 0,025 % cadmium by weight,
- more than 0,4 % lead by weight.
- Alkaline manganese batteries containing more than 0,025 % mercury by weight placed on the market
ANNEX II
- Those appliances whose batteries are soldered, welded or otherwise permanently attached to
- Reference cells in scientific and professional equipment, and batteries and accumulators placed in
- Portable appliances, where replacement of the batteries by unqualified personnel could present safety
zaisyfang (威望:3) (广东 深圳) 电子制造 员工 - 小破孩
1.RoHS指令管制對象不包含電池,電池的管制用電池指令2006/66/EC及91/157/EC.
2.LZ公布的指令為91/157/EC,而此指令將在2008/9/26廢止.
不對之處還請各位指正!
