过程流程图
在制作过程流程图时,是否要把返工、返修的过程也要放在里面,如需放入,如何制作比较合理?
will.fchen (威望:0)
if 100% of parts needed to be inspected and rework, this process step shall be shown in the flow chart;if the rework only performed with defective parts found in the process, not shown this process step in flow chart, but you have to create work instruction for reworking
2 个回复,游客无法查看回复,更多功能请登录注册
