Minitab又升级啦
Minitab15.1.1版已升级为Minitab15.1.2,只有注册用户可通过update, 从start Minitab 15 and select Help > Check for Updates下载install the Minitab 15.1.2
This update applies to both Minitab 15.1.0 and Minitab 15.1.1. This update DOES NOT apply to the Minitab 15 trial, the 6-month or 12-month rental versions of Minitab 15 from e-academy.com, or to any earlier version of Minitab.
Several issues have been resolved in Minitab 15.1.2, including:
1.Factorial designs with a non-hierarchical model produce incorrect fitted values, residuals, and prediction results for uncoded units.
2.An assertion failure occurs when updating an Individuals Chart created with date/time values for historical stages.
3.Minitab doesn’t use the appropriate decimal symbol from Regional Settings when using the keypad.
4.If an invalid default file location is specified by an administrator during installation, a message is generated regarding the invalid location, even after a valid location has been set.
5.Performance is slow for searching and replacing large columns of text in the Data window.
snowfoxbbs (威望:0) (福建 厦门) 电子制造 经理
中文版的激活也很简单,先安装激活英文版后,再下载中文版安装,安装后把英文版中的主文件Mtb.exe文件覆盖在中文版的对应目录中就可以了,呵呵(注册机PM我)
中英文试用版的下载地址:
英文:http://fs1.minitab.com/store/m ... p.exe
中文:http://fs1.minitab.com/store/m ... p.exe
29 个回复,游客无法查看回复,更多功能请登录注册
