MINITAB15.1.20
誰幫忙看一下MINITAB15.1.20更新了哪些工具?
powereyes (威望:2)
Part 4B. Problems Resolved in Minitab 15.1.2
Several specific issues have been resolved in Minitab 15.1.2, including:
Item 1
Factorial designs with a non-hierarchical model produce incorrect fitted values, residuals, and prediction results for uncoded units. (PR-124852)
Item 2
The Optimization Plot for coded factorial designs may incorrectly display uncoded units when using crosshairs or the Input New Level dialog box. (PR-128805)
Item 3
Optimization Plots may be unreadable if a solid figure region is chosen. (PR-125132)
Item 4
Calculations for the Kolmogorov-Smirnov Normality Test do not handle tied observations in the standard way. (PR-9033)
Item 5
The scale range of the Hazard Plot is incorrect with exponential distributions and a scale parameter of 20 or greater. (PR-131474)
Item 6
A crash can occur when producing a Line Plot using tabled data with two or more graph variables and a paneling variable. (PR-133194)
Item 7
If a Time Series Plot is created using subset data, attempting to edit the last data label on the chart can cause Minitab to crash. Also, for each data label, the value in the Text field of the Edit Data Label dialog box is incorrect. (PR-133058)
Item 8
An assertion failure occurs when updating an I Chart created with date/time values for historical stages. (PR-127255)
Item 9
Minitab doesn’t use the appropriate decimal symbol from Regional Settings when using the keypad. (PR-7290)
Item 10
If an invalid default file location is specified by an administrator during installation, a message is generated regarding the invalid location, even after a valid location has been set. (PR-41779)
Item 11
Opening an Excel worksheet in .xlsx (Excel 2007) format opens blank worksheets, as well as those containing data. (PR-128217)
Item 12
Performance is slow for searching and replacing large columns of text in the Data window. (PR-7545)
Item 13
A numerical error and crash occurs when printing from ReportPad with the cursor in the right pane. (PR-129921)
5 个回复,游客无法查看回复,更多功能请登录注册
