Here is the example to show you how to check if the plastic material is UL approved.
For example, I want to find the plastic material “PA-757” from supplier “Chi Mei” with Cert number E56070.
Go to UL.com, and click the link for certification directory:
Input your UL cert number into the box for E number, E56070.
Then, the window will then show the database of that company and their material under the same certificate.
Scroll down the windows, you will then find the "PA-757(+)" is listed in this UL certificate.
carlo (威望:0)
hope can help you.
