jmp8 发布, 想尝鲜的朋友可以去看看了
Key Features
New Platforms
The new Graph Builder platform lets you construct graphs interactively as you explore your continuous and categorical data.
Drag and drop to instantly create scatterplots, bar charts, histograms, trend lines, box plots and more.
Visually compare across grouping levels for insightful analysis.
Partition data by both continuous and categorical variables to easily see interactions.
The new Choice platform helps you discover consumer preferences so you can tailor the features of products and services to consumer desires.
Discover differences in market segments to create targeted offerings.
Use what you know about consumer preferences to design your study.
The integrated Profiler helps you understand, visualize and optimize products and services.
Get utility scores for segmenting/clustering your data.
Use Firth bias-corrected maximum likelihood estimators.
New additions to the Reliability platform improve your understanding of product and part lifetimes.
Use Fit Life by X to analyze lifetime events for accelerated test data. Compare different distributions at the same factor level or the same distribution across different factor levels.
Use Life Distribution to find the most suitable distributional model for your time-to-event data and make predictions. Weibull, Lognormal, Fréchet, Extreme Value and other distributions are available.
Use Competing Causes analysis to explore failure causes in a system and understand the effects of repair.
Mixture Profiler shows response contours for mixture experiment models, where three or more factors in the experiment are components in a mixture.
Visualize and optimize response surfaces resulting from mixture experiments.
New Platforms
15 个回复
duxy640 (威望:0) - 200 字节以内
不支持自定义 D...
