塑胶件不良英语
blister 起泡
blooming 起霜
blow hole 破孔
blushing 泛白
body wrinkle 侧壁皱纹
breaking-in 冒口带肉
bubble 膜泡
burn mark 糊斑
burr 毛边
camber 翘曲
cell 气泡
center buckle 表面中部波皱
check 细裂痕
checking 龟裂
chipping 修整表面缺陷
clamp-off 铸件凹痕
collapse 塌陷
color mottle 色斑
corrosion 腐蚀
crack 裂痕
crazing 碎裂crazing 龟裂
deformation 变形
edge 切边碎片
edge crack 裂边
fading 退色
filler speak 填充料斑
fissure 裂纹
flange wrinkle 凸缘起皱
flaw 刮伤
flow mark 流痕
galling 毛边
glazing 光滑
gloss 光泽
grease pits 污斑
grinding defect 磨痕
haircrack 发裂
haze 雾度
incrustation 水锈
indentation 压痕
internal porosity 内部气孔
mismatch 偏模
mottle 斑点
necking 缩颈
nick 割痕
orange peel 橘皮状表面缺陷
overflow 溢流
peeling 剥离
pit 坑
pitting corrosion 点状腐蚀
plate mark 模板印痕
pock 麻点
pock mark 痘斑
resin streak 树脂流纹
resin wear 树脂脱落
riding 凹陷
sagging 松垂
saponification 皂化
scar 疤痕
scrap 废料
scrap jam 废料阻塞
scratch 刮伤/划痕
scuffing 深冲表面划伤
seam 裂痕
shock line 模口挤痕
short shot 充填不足shrinkage pool 凹孔
sink mark 凹痕
skin inclusion 表皮折迭
straightening 矫直
streak 条状痕
surface check 表面裂痕
surface roughening 橘皮状表皮皱折
surging 波动
sweat out 冒汗
torsion 扭曲
warpage 翘曲
waviness 波痕
webbing 熔塌
weld mark 焊痕
whitening 白化
wrinkle 皱纹missing part漏件
wrong part错件
excessive defects过多的缺陷
critical defect极严重缺陷
major defect主要缺陷
minor defect次要缺陷
not up to standard不合规格
dimension/size is a little bigger尺寸偏大(小)
cosmetic defect外观不良
slipped screwhead/slippery screw head螺丝滑头
slipped screwhead/shippery screw thread滑手
speckle斑点
mildewed=moldy=mouldy发霉
grease/oil stains油污
inclusion杂质
painting peel off脏污
shrinking/shrinkage缩水
mixed color杂色
scratch划伤
flash(塑件)毛边
paulcui (威望:1) (上海 徐汇) 电信通讯 员工
挺全面的,囊括了塑胶件几乎全部的不良现象。
6 个回复,游客无法查看回复,更多功能请登录注册
