seeking answer for GR&R questions
great confusion encountered during supplier audit about GR&R recently, anybody can clarify them for me here? thanks in advance.
1.in what situation supplier should conduct GR&R study? the answer i got from supplier is when costomer required, that is not a correct reply, i know one situation is that they introducing a new gauge, they should complete Bias, Stability & Linearity analysis then GR&R, any other situation??????
2.what is the diference between GR&R and PT value, should the two criteria both be evaluated in a GR&R report? or one can represent another??????
3.all GR&R reports supplier submitted me are just including a result of GR&R% value and ndc value, is that enough??? should supplier conduct further analysis such as Xbar-R/S chart for the result?????
4.any good heart man can share me some excel templetes for Bias, Stability, Linearity analysis, as well as Xbar-R chart??????
安靠 (威望:0)
1.MSA is not required for all measuringf equipments,but it's required for all representative measuring equipment used to decide whether the product being built at manufacturing equipment is acceptable or not based on the quality criteria among the measuring equipment used for measuring the items。
2.PT value means is Precision to tolerance,so This method shall be applied to the measuring equipment not affected by operator. An example for this method is for automatic scanner.
Hope it'll helpful to you !
8 个回复,游客无法查看回复,更多功能请登录注册
