TS16949:2009
**TS16949:2009
刚看到一些消息,又有事要做了。看来TC/176还是会找事做的。牵一发动全身啊。:lol: **
Revised Standard标准修订
The latest revision of ISO/TS 16949:2009 will be issued during the first quarter 2009, following the ballot of the ISO TC176 and reflects the changes in ISO 9001:2008.
根据ISO/TC176委员会的投票结果,为了反映ISO9001:2008的变化, ISO/TS16949的最新版本(2009版)将在2009年第一季度发布。
Obtaining Copies of the Standard标准副本的获得
Once issued, copies of the standards can be obtained from the AIAG at http://www.aiag.org.
一旦发布之后,标准的副本可以从AIAG网站http://www.aiag.org获得。
Transition Guidelines 转换指南
1) No new requirements 没有新的要求
ISO/TS 16949:2009 introduces no new or changed requirements. ISO 9001:2008 is based on clarifications or amendments to the existing requirements of ISO 9001:2000 and those that are intended to improve consistency with ISO 14001:2004.
ISO/TS16949:2009没有增加新的或更改的要求。ISO 9001:2008建立在对 ISO 9001:2000现有要求的澄清或改进以及提高和ISO 14001:2004的一致性 的基础上。
2) Application应用
Certification Bodies and Organizations are expected to understand and apply the amendments to ISO/TS 16949:2009. Application of the clarifications related to ISO 9001:2008 requirements in the boxed text of ISO/TS 16949:2009 is effective not later than 120 days after the release of ISO/TS 16949:2009.
希望认证机构和组织能够理解和应用ISO/TS 16949:2009中的修订部分。ISO/TS 16949:2009发布之后的120天内,必须应用ISO/TS 16949:2009标准条文的方框中的ISO 9001:2008要求的修改部分。
3) Certification status to ISO/TS 16949:2002
ISO/TS 16949:2002的认证状态
The certification status to ISO/TS 16949:2002 remains in effect for the certification life. Certification to ISO/TS 16949:2009 is recognized with the effective date of the release of ISO/TS 16949:2009. The certification to ISO/TS 16949:2009 is not an upgrade and its term is the same as the current ISO/TS 16949:2002 certificate.
在证书的有效期内,ISO/TS 16949:2002认证证书仍然维持有效。自ISO/TS 16949:2009发布之日起,即可以进行ISO/TS 16949:2009认证。ISO/TS 16949:2009认证不是一种升级,其证书有效期与现有之ISO/TS 16949:2002证书相同。
4) Certificates issued to ISO/TS 16949:2009
ISO/TS 16949:2009证书的颁发
IATF recognized certificates to ISO/TS 16949:2009 may be issued upon request by an organization (client) after official publication and after a regularly scheduled surveillance audit, but are not required until the next recertification audit.
ISO/TS 16949:2009正式发行之后,在组织(客户)的要求下,经过计划中的监督审核之后,IATF允许颁发ISO/TS 16949:2009证书,但并不强制要求如此。在下一次换证审核时,必须颁发ISO/TS 16949:2009证书。
zyz2001218 (威望:0) (山东 青岛) 汽车制造相关 主管 - 从事管理工作
真的,假的,刚听说,你是从那里得到的消息?准确吗?
40 个回复,游客无法查看回复,更多功能请登录注册
