ROHS指令新增六项豁免
ROHS指令新增六项豁免
欧盟RoHS 指令新增6 项豁免欧盟OJ 刊登了2009/443/EC ,新增了6 项RoHS 指令的豁免,分别如下:
33. Lead in solders for the soldering of thin copper wires of 100 μm diameter and less in power transformers. 电力变压器中直径100 微米及以下细铜线所用焊料中的铅
34. Lead in cermet-based trimmer potentiometer elements. 金属陶瓷质的微调电位计中的铅
35. Cadmium in photoresistors for optocouplers applied in professional audio equipment until 31 December 2009. 2009 年12 月31 日前专业音频设备的光耦合器中使用的光敏电阻的镉
36. Mercury used as a cathode sputtering inhibitor in DC plasma displays with a content up to 30 mg per display until 1 July 2010. 2010 年7 月1 日前直流等离子显示器中阴极溅射抑制剂中的汞,其含量不得超过30 毫克/显示器
37. Lead in the plating layer of high voltage diodes on the basis of a zinc borate glass body. 以硼酸锌玻璃体为基础的高压二极管的电镀层的铅
38. Cadmium and cadmium oxide in thick film pastes used on aluminium bonded beryllium oxide. 用氧化铍连接铝制成的厚膜浆料中镉和氧化镉
lala_008 (威望:0)
谢谢楼主分享转载。
4 个回复,游客无法查看回复,更多功能请登录注册
