产品审核不合格品处置
产品审核不合格品怎么处置呢?比如关键或重要特性的不合格品肯定是要隔离和处置的,那么如果是次要特性的不合格品呢?是否也都要不合格品评审及返工单处置?是否无论关键或重要特性出现不合格项每次都要采取纠正及预防措施?希望各位同学能够指教一二。
hanye (威望:0)
how are these situations defined in your document <Control of non-conformancing procedure>? if there haven't this sort of description,you can call together your Technical engineer, QA, Sales to settle this down.
In my opinion, any non-conformancing product need to be reviewed and have the subsequent disposition.
But, however, every different product category have its own function and characteristic, it should be decided by yourself whether that issue need to be reviewed or not.
10 个回复,游客无法查看回复,更多功能请登录注册
叮铛
叮铛
有点懒,有点想虚度人生,但生活所迫,必须要每天打起精神。
