初次接触这份检查报告,望有经验者能解答一二,不胜感激
1: What is the process for ensuring the quality of the components used in manufacturing?
在生产过程中如何担保散件的质量?
2 :What is your manufacturing process control?
如何控制生产过程?
3:What is the IQC sampling rate?
进料检验的抽样率是多少?
4 :What is the OQC sampling rate?
出货检验的抽样率是多少?
5: What is the process carried out once a product fails at OQC?
一旦在出货检验中产品不合格怎么处理?
6:What is the process involved in treating product failure during the manufacturing?
在生产过程中如何处理坏的产品?
7: What is the DOA rate of the specific product
产品送到目的地是时已经坏了的几率是多少?
Do you have a system of analysing the root causes of DOA and implement action with intimation to the supplier?
你们是否有分析送至目的地产品作废的原因?以及对客户有个说法?
9 What is the failure rate of key products?
产品报废率是多少?
What is your policy on providing buffer stock for the specific product?
关于特殊产品你们的储存货物的政策是什么?
11 What is your policy of spares supply?
节省支出的政策是什么?
12 Do you have diagnostic software for isolating the faulty component?
13 Do you have a trouble –shooting bulletin, which has the details of the error messages and components to check for?
vpvp1960 (威望:0)
1.生产中使用的零件质量如何保证?应该是指来料的质量吧
  1. 关键产品的不良率
对特殊产品管理缓冲库存的方法
11备件供应管理方法
12是否有诊断软件能测出故障零件
13.是否有问题改善报告,里面包括具体的不良信息及所要检查的零件。
应该是做装配或整机的吧,试着翻译的,理解了内容就好回答了
6 个回复,游客无法查看回复,更多功能请登录注册
