汽车材料常规检测项目及标准列表
耐化学性 Resistance to Chemical
GM 9900P:2002
MO 133 method 3
MO133 method 5
MO133 method 5
雾化试验 Fogging
TSM 0503G
NES M0161
8460Z-SEA-0000
NES M7081
气味试验 Odor Test
SAE J1351
FLTM BO 131-01
ES-X60250
PV3900:2000
GME 60276
D10 5517
VDA 270
8830Z-SV4-J010-M1:1992
TSM0505G
耐刮擦性 Resistance to scratching
TL226-2006 3.8
GMN 3943
FLTM BN108-13:2001
DVM-0019-MA
耐磨性 Abrasion Test
GM9515P:1998
ASTM D4060-07
NES M0136-2002
MS 82-3101
FLTM BN 108-02:2001
"石击测试
Chip resistance" SAE J400-2002
ASTM D3170-03(2007)
GME 60268-96
GMW14700
GM9508P
MGR ES30.AD.149
ISO 20567-1-2005
NES M0007 Section 28
DIN EN ISO 20567-1-2007
FLTM BI 157-06
"耐低温冲击
Resistance to cold impact" WSK-M98P9-A 3.8.4
"耐燃油
Fuel resistance " WSK-M98P9-A 3.10 and FLTM BO 101-05
Paint repair oven resistance WSK-M98P9-A 3.6.1 condition A
"表面尘土量
Surface Dust Quantity" 8330Z-SV4-J010-H1
"温度循环测试
Thermal cycle resistanc test " MES PA 44010A(TH-02, WIN MES PW PT001)
内侧清洁度 YS/T 440
"压缩率
复原率" 8830Z-SV4-J010-M1:1992
耐热性 8830Z-SV4-J010-M1:1992
燃烧性 TSM5514G, 5608G, 0500G
"耐冲击测试
Impact resistance " ES-X 60210 4.11
"应力开裂试验
Stressing cracking " DVM-0027-MA
擦伤性 TL 226
Steam autoclave aging GM2101M-04 and ASTM D3574-08 test J procedure J2 ,test C
Wicking GM2101M-04 and GM 9146P-4.1-1988
增塑剂含量 标致D45 1601
Resistance to scuffing DVM-0026-MA
胺类挥发物 D 10 5496
"漆膜耐溶剂性
Solvent resistance" 7710Z-SCC-9000 clause 6.11
7710Z-SCC-9000 clause 6.12
"耐磨擦性(平面磨擦)
Plane Abrasion" MS 82-3101
"耐磨擦性(曲面磨擦)
Bend abrasion" MS 82-3101
0 个回复,游客无法查看回复,更多功能请登录注册
