FTA
[分享]FTA
FAT
OBJECTIVES
 Change the participants ATTITUDE regarding problem solving in all areas (Industry, Suppliers, Projects) in order to be more LOGICAL
Before talking format :
Let’s be aware of our situation and weaknesses
Let’s change our way of thinking for Problem
Solving, in every area : Industry, Projects,
Suppliers
Thierry Morin commented that:
Quality is one of the biggest weaknesses of
Our Company
Quality is fundamental to gaining market share
In Japanese culture SanGenShugi is an expression
that means:
SAN - meaning “3”
GEN - meaning “Real” or Actual” (“3 R”: Real parts, Real Place, Reality)
SHUGI - meaning “Ideology”
SanGenShugi is a common-sense approach to problem solving
“Quick Response” PDCA
When a problem arises , it has first to be addressed with immediate action to protect customer
To do this, we use the Quick Response PDCA
Containment
The first priority of the team is to contain the problem to protect the Customer
Many times the first step in the containment process is to implement a Sorting activity
Quick Response PDCA within 24 HOURS
The Quick Response PDCA is the first immediate answer
The second step is to understand the root cause of the problem and solve it. For this, we have Analysis PDCA.
“Analysis” PDCA
“Analysis” PDCA
The objective is Zero Incident
(Corresponding situation
before incident happens)
After isolating the problem with immediate countermeasures, the next step is to identify the root cause
We first observe Standard and real data by using the
Factor Tree Analysis tool
“Analysis” PDCA : 5 WHY’s
“Analysis” PDCA
“Analysis” PDCA
Once the root cause has been established and verified we now start establishing the solution(s).
The pre-requisites for success in solution identification and selection are:
A good practice of San Gen Shugi : Observe carefully the parts and the process
A clear and logical understanding of the Mechanism that has created the defect
An adequate solution that is logically linked to the root cause found
Now that the solutions have been determined, it is important that we take the steps to fully implement them.
“Analysis” PDCA
PDCA - CHECK Stage
Immediately after implementation of the actions defined in the Analysis PDCA, we check to see that our actions were adequate.
“Analysis” PDCA
PDCA - ACT Stage
PDCA - ACT Stage
Put in place new standards and/or modify existing standards to reflect the actions that have been taken
PDCA - ACT Stage
Generalize the countermeasures :
To similar lines of the sites
To other sites of same
Division, Branch
To other sites of customers
“Analysis” PDCA
PDCA - ACT Stage
Once actions taken to correct problems, process controls have been updated and training of all pertinent personnel is complete, we must go about the process of closing the PDCA.
“Analysis” PDCA
PDCA - ACT Stage
It is prudent in good problem solving not to assume success at the first set of results!!
It is advised before completely closing the problem solving activity to take further measurements.
There should be no deterioration of the measurements and, if stable, then you can be sure all variation has been taken into account.
“Analysis” PDCA
PDCA - ACT Stage
Make sure everyone is aware of what has been done and don’t forget to recognize the team!
PDCA RoadMap
Obstacles in Implementation
Questions that may come
Recommendations
Remember, San Gen Shugi is the basis!
Speak with Data!
Make quick response and deep analysis of Quality issues!
Think logically!
Follow without compromise the PDCA methodology!
I Quick response PDCA - Analysis PDCA
II Factor Tree Analysis
based on 3 Gen Shugi Activity
lg8634 (威望:0) - 我于茫茫人海中觅我唯一灵魂之伴侣,得之,我幸,不...
:(me too,it's out of order.
4 个回复,游客无法查看回复,更多功能请登录注册
