帮忙翻译一下;中译英
FAI for revision changes are required only for attributes affected by the specification change if an approved FAI is on file for the previous revision;
non-critical sub-component part numbers FAI do not have to be submitted to brooks for approval ;
critical sub-component part numbers FAI must be submitted to brooks for approval before assembly level FAI is submitted
q1j2w3 (威望:0) (广东 佛山) 其它行业 员工
假如前一版本的FAI是受控的话,版本变更的FAI仅仅是要求对受影响到的规格
不重要的代替元件FAI不需要提交布鲁克斯批准,但重要的代用料的FAI在组装前是需要提交的。
语言组织有点乱,请谅解!
