有没电机行业的,帮忙翻译下,谢谢!
以下是测试项目,很多都看不懂,那位大哥大姐帮忙看下,不胜感激:
Long Term tests
FW/ Bumn In
Electrical Tests
Current Regulator PWM
Standby power test
Start test
Ground Bond
Ring Wave testing of LV transformer
Power Line Drop Out
EFT
Chattering Relay
Line transient
Conducted EMI
ESD
PWB Fuse trace
Mechanical Tests
Shipping Test
Thermal Shock
Humidity Soak
Mechanical Shock
Mechanical Vibration
Blower windmilling test
Blower Wheel Stability
Jammed Blower Test
Bearing HASS/Broan Endurance Testing
Calibration Study
Dyno Curves
Long Term tests
FW/ Bumn In
Electrical Tests
Standby power test
Start test
Ground Bond
Power Line Drop Out
EFT
Chattering Relay
Line transient
Conducted EMI
ESD
PWB Fuse trace
Mechanical Tests
Shipping Test
Thermal Shock
Humidity Soak
Mechanical Shock
Jammed Blower Test
Calibration Study
Dyno Curves
0 个回复
