分享][下载]化学原料的MSDS(英文版)
[GLYCOLIC ACID (68 - 72%)
MSDS Number: G6820 --- Effective Date: 12/08/96
  1. Product Identification
Synonyms: Hydroxyacetic acid; hydroxyethanoic acid
CAS No.: 79-14-1
Molecular Weight: Not applicable to mixtures.
Chemical Formula: HOCH2COOH in H2O
Product Codes: J.T. Baker: M822 Mallinckrodt: 2742
  1. Composition/Information on Ingredients
Ingredient CAS No Percent Hazardous
Glycolic Acid 79-14-1 68 - 72% Yes
  1. Hazards Identification
Emergency Overview
DANGER! CORROSIVE. HARMFUL IF SWALLOWED OR INHALED. CAUSES SEVERE IRRITATION AND BURNS TO EVERY AREA OF CONTACT.
J.T. Baker SAF-T-DATA(tm) Ratings (Provided here for your convenience)
Health Rating: 1 - Slight
Flammability Rating: 1 - Slight
Reactivity Rating: 1 - Slight
Contact Rating: 2 - Moderate
Lab Protective Equip: GOGGLES; LAB COAT; VENT HOOD; PROPER GLOVES
Storage Color Code: Orange (General Storage)
Potential Health Effects
Information on the human health effects from exposure to this substance is limited.
Inhalation:
Inhalation is irritating to the mucous membrane and upper respiratory tract. In extreme cases, severe irritation and burns may result.
Ingestion:
Material causes irritation and burns to digestive tract.
Skin Contact:
Causes irritation and burns to the skin.
Eye Contact:
Can cause severe irritation or burns with eye damage.
Chronic Exposure:
No information found.
Aggravation of Pre-existing Conditions:
  1. First Aid Measures
Inhalation:
Remove to fresh air. If not breathing, give artificial respiration. If breathing is difficult, give oxygen. Call a physician.
Ingestion:
DO NOT INDUCE VOMITING. Give large quantities of water. Never give anything by mouth to an unconscious person. Call a physician immediately.
Skin Contact:
In case of contact, immediately flush skin with plenty of water for at least 15 minutes while removing contaminated clothing and shoes. Wash clothing before reuse. Call a physician.
Eye Contact:
Immediately flush eyes with plenty of water for at least 15 minutes, lifting lower and upper eyelids occasionally. Get medical attention immediately.
  1. Fire Fighting Measures
Fire:
Not considered to be a fire hazard.
Explosion:
Not considered to be an explosion hazard.
Fire Extinguishing Media:
Water spray, dry chemical, alcohol foam, or carbon dioxide.
Special Information:
In the event of a fire, wear full protective clothing and NIOSH-approved self-contained breathing apparatus with full facepiece operated in the pressure demand or other positive pressure mode.
  1. Accidental Release Measures
Ventilate area of leak or spill. Wear appropriate personal protective equipment as specified in Section 8. Isolate hazard area. Keep unnecessary and unprotected personnel from entering. Contain and recover liquid when possible. Neutralize with alkaline material (soda ash, lime), then absorb with an inert material (e. g., vermiculite, dry sand, earth), and place in a chemical waste container. Do not use combustible materials, such as saw dust. Do not flush to sewer!
  1. Handling and Storage
Keep in a tightly closed container, stored in a cool, dry, ventilated area. Protect against physical damage. Isolate from incompatible substances. Containers of this material may be hazardous when empty since they retain product residues (vapors, liquid); observe all warnings and precautions listed for the product.
  1. Exposure Controls/Personal Protection
Airborne Exposure Limits:
None established.
Ventilation System:
A system of local and/or general exhaust is recommended to keep employee exposures as low as possible. Local exhaust ventilation is generally preferred because it can control the emissions of the contaminant at its source, preventing dispersion of it into the general work area. Please refer to the ACGIH document, Industrial Ventilation, A Manual of Recommended Practices, most recent edition, for details.
Personal Respirators (NIOSH Approved):
For conditions of use where exposure to the substance is apparent, consult an industrial hygienist. For emergencies, or instances where the exposure levels are not known, use a full-facepiece positive-pressure, air-supplied respirator. WARNING: Air purifying respirators do not protect workers in oxygen-deficient atmospheres.
Skin Protection:
Wear impervious protective clothing, including boots, gloves, lab coat, apron or coveralls, as appropriate, to prevent skin contact.
Eye Protection:
Use chemical safety goggles and/or full face shield where dusting or splashing of solutions is possible. Maintain eye wash fountain and quick-drench facilities in work area.
  1. Physical and Chemical Properties
Appearance:
White to straw colored liquid.
Odor:
Burnt sugar odor
Solubility:
Soluble in water.
Specific Gravity:
1.27
pH:
Aqueous solution: 2.5 (0.5 %), 1.7 (10 %)
% Volatiles by volume # 21C (70F):
Boiling Point:
Melting Point:
10C (50F)
Vapor Density (Air=1):
Vapor Pressure (mm Hg):
Evaporation Rate (BuAc=1):
  1. Stability and Reactivity
Stability:
Stable under ordinary conditions of use and storage.
Hazardous Decomposition Products:
Carbon dioxide and carbon monoxide may form when heated to decomposition. Can react with most common metals to release flammable hydrogen gas.
Hazardous Polymerization:
Will not occur.
Incompatibilities:
Strong oxidizers.
Conditions to Avoid:
Incompatibles.
  1. Toxicological Information
Oral rat LD50: 1950 mg/Kg (dry material)
--------\Cancer Lists\------------------------------------------------------
---NTP Carcinogen---
Ingredient Known Anticipated IARC Category
Glycolic Acid (79-14-1) No No None
  1. Ecological Information
Environmental Fate:
Environmental Toxicity:
  1. Disposal Considerations
Whatever cannot be saved for recovery or recycling should be handled as hazardous waste and sent to a RCRA approved incinerator or disposed in a RCRA approved waste facility. Processing, use or contamination of this product may change the waste management options. State and local disposal regulations may differ from federal disposal regulations. Dispose of container and unused contents in accordance with federal, state and local requirements.
  1. Transport Information
Not regulated.
  1. Regulatory Information
--------\Chemical Inventory Status - Part 1\---------------------------------
Ingredient TSCA EC Japan Australia
Glycolic Acid (79-14-1) Yes Yes Yes Yes
--------\Chemical Inventory Status - Part 2\---------------------------------
--Canada--
Ingredient Korea DSL NDSL Phil.
Glycolic Acid (79-14-1) Yes Yes No Yes
--------\Federal, State & International Regulations - Part 1\----------------
-SARA 302- ------SARA 313------
Ingredient RQ TPQ List Chemical Catg.
Glycolic Acid (79-14-1) No No No No
--------\Federal, State & International Regulations - Part 2\----------------
-RCRA- -TSCA-
Ingredient CERCLA 261.33 8(d)
Chemical Weapons Convention: No TSCA 12(b): No CDTA: No
SARA 311/312: Acute: Yes Chronic: No Fire: No Pressure: No
Reactivity: No (Pure / Liquid)
Australian Hazchem Code: No information found.
Poison Schedule: No information found.
WHMIS:
This MSDS has been prepared according to the hazard criteria of the Controlled Products Regulations (CPR) and the MSDS contains all of the information required by the CPR.
  1. Other Information
NFPA Ratings: Health: 3 Flammability: 1 Reactivity: 0
Label Hazard Warning:
Label Precautions:
Do not breathe vapor or mist. Do not get in eyes, on skin, or on clothing. Keep container closed. Use only with adequate ventilation. Wash thoroughly after handling.
fredliu (威望:0)
这也叫资料呀,我有很多谁要,只要留下邮件地址、就行了,但我不会放在上面的,因为占用太多的有限资源了
3 个回复,游客无法查看回复,更多功能请登录注册
