TS16949:2009版供应商体系的补充说明
SI 1 09 October 2009
ISO/TS16949:2009
7.4.1.2 Supplier Quality Management System Development
The organization shall perform supplier quality management system development with the goal of supplier conformity with this Technical Specification. Conformity with ISO9001:2008 demonstrated by a certification by an accredited third party certification/registration body or through a second party audit process is the first step in achieving this goal.
• The organization’s second party audit process shall be consistent with the automotive process approach, including evidence of planning, supplier readiness and supplier performance. The organization shall demonstrate the competence of the auditors undertaking the 2nd party audits. Records of the audits reports shall be maintained. Note: Guidance can be found in the IATF Auditor Guide, ISO 17021 and ISO19011.
• After the initial audit, the second party surveillance audits shall be conducted at least
annually.
• The prioritization of suppliers for development depends upon, for example, the
supplier’s quality performance and the importance of the product supplied.
• The organization shall have decision criteria for determining “specially designated
small suppliers” wherein certain specified elements of ISO9001:2008
ISO/TS16949:2009 may be waived. Records of the established criteria and decision taken accordingly shall be maintained. “Small” here above may refer to the volume supplied to the automotive industry or to the organization.
• Refer to OEM Vehicle Manufacturer customer specifics for 2nd Party audit
requirements for the organization who is a direct supplier to the OEM.
• During the agreed ISO9001:2008 and ISO/TS16949:2009 transition process
ISO9001:2000 and ISOTS16949:2002Certificates shall be deemed as acceptable.
vv6601 (威望:4) (广东 深圳) 电子制造 经理
怎么无法修改了?
是对7.4.1.2供应商质量管理体系开发的说明,在标准中供应商必须通过第三方的ISO9001:2008认证,更改为通过第三方的ISO9001:2008认证或通过第二方认可,即可。
为未通过ISO9001的供应商增加了一个验证方式,通过客户的验证也行。
