How can I calculate the following data?[求助]
The data in table are viscosity measurements by lot. For this measurement systems analysis study, consider that the reading for the samples represent duplicate measurements because they were obtained using the same methods, personnel and instruments.
Lot : 1 2 3 4 5 6 7
Sample 1 : 20.48 19.37 20.35 19.87 20.36 19.32 20.58
Sample 2 : 20.43 19.23 20.39 19.93 20.34 19.30 20.68
Range :
1) Calculate Range
2) Calculate sm
3) Calculate sp
4) Calculate the number of distinct categories
5) Calculate Gage R&R %
:(:o
Lot : 1 2 3 4 5 6 7
Range :
1) Calculate Range
2) Calculate sm
3) Calculate sp
:(:o
tina (威望:0)
4.you can use JMP to calculate it(one way anova),JMP is a good tool.
5.i think the data isn't enough for gr&r.
