CCD-当中星点位置何计算?
在实验设计当选择RSM =>Central Composite,当中关于星点位置是如何计算的?期望高人给予指点。
以下是Minitab中找到解释:
Alpha for axial points
The distance of each axial point (also called star point) from the center in a central composite design. This value (a), along with the number of center points, determines whether a design can be orthogonally blocked and is rotatable.
举例来说就是:
当因子数为2时,Default Alpha=1.414 (如何计算1.414)
当因子数为3时,1 Block, Default alpha=1.682(如何计算1.682)
2 Block, Default alpha=1.633(如何计算1.633)
以下是Minitab中找到解释:
举例来说就是:
4 个回复
Jack315 (威望:4) (江苏 苏州) 家电/电器 经理
