Case hardened 指的是哪种热处理?
Case hardened 是渗碳淬火吗?
还是指的是一种表面硬化,包括渗碳淬火。碳氮共渗,感应淬火之类的?
Surface hardening 有是什么意思?
期待高手中..........
aong (威望:2)
Case hardening or surface hardening is the process of hardening the surface of a metal, often a low carbon steel, by infusing elements into the material's surface, forming a thin layer of a harder alloy.
就是表面渗碳硬化
