SPC中英文名词术语索引
人械料法环4MIE 80:20原理80:20Principle 准确度Accuracy
成品改善Action on Output 制程中对策Action on the Process 人员变异Appraiser Variation
计数值Attribute Data 平均数Average 中位数平均Average of Median
全距平均Average of Range 标准差平均Average of Standard Deviation
平均数-全距管制图Average-Range Control Chart 二项分配Binomial Distribution
平均数-标准差制图Average-Standard Deviation Control Chart 中心线Center Line;CL
中央极限定理Central Limit Theorem 管制界限Control Limits
持续改善Continual Improvement 管制图Control Chart 分散Dispersion
管制计划Control Plan 计件Count by Pieces 计点Count by Points
关键制程特性Critical Process Characteristics 共同原因Common Cause
每百万缺点数管制图Defect Parts Per Million Control Chart 分配Distribution
关键产品特性Critical Product Parameter 仪器变异Equipment Variation
连续随机变数Continuous Random Variable 估计平均数Estimated Average
离散随机变数Discrete Random Variable 单位缺点数Defects Per Unit
单位缺点数管制图Defects Per Unit Contro Chart 指数分配Exponential Distribution
估计不良率Estimated Process Percent Defectives 次数分配Frequency Distribution
估计标准差Estimated Standard Deviation 漏斗实验Funnel Experiment
个别值-移动全距管制图Individual-Moving Range Control Chart 仪器设备Gauge
每百万缺点数Defects Part Per Million;dppm 仪器设备能力研究GRR Study
绩效报告Information about Performance 直方图Histogram
固有制程变异Inherent Process Variation 个别值Individual
短期制程能力研究Short Term Process Capability Study 中心位置Location
管制下限Lower Control Limit;LCL 管制上限Upper Control Limit;UCL 中位数Median
规格下限Lower Specification Limit;LSL 混批Mixed Lot
量测系统误差Measurement System Error 标称植Nominal
中位数-全距管制图Median-Range Control Chart 常态分配Normal Distribution
不良数管制图Number of Defectives Control Chart 缺点数Number of Defects
缺点数管制图Number of Defects Control Chart 不良数Number of Defectives
每百万不良数Parts Per Million;ppm 不在管制状态下Out of Control
制程能力图Process Capability Chart 过度调整Overadjustment
制程绩效指数Process Performance Index 柏拉图Pareto Diagram
不良率管制图Percent Defectives Control Chart 不良率Percent Defectives
制造流程图Process Capability Chart 卜氏分析Poission Distribution
长期制程能力研究Long Term Process Capability Study 群体Population
简单随机抽样Simple Random Sampling 精密度Precision
分段随机抽样Stage Random Sampling 制程系统Process
统计制程管制Ststistical Process Control;SPC 制程能力Process Capability
制程能力图Run Chart 样本Sample 全距Range
抽样Sampling 抽样分配Sampling Distribution 合理的分组Rational Subgrouping
偏态Skewness 再生性Reproducibility 再现性Repeatability
特殊原因Special Cause 稳定性Stabiity 规格界限Specification Limits
标准差Standard Devivation 分层分析Stratification 分层批Stratified Lot
分层随机抽样Stratified Random Sampling 组平均数Subgroup Average
组标准差Subgroup Standard Deviation 组全距Subgroup Range
规格上限Upper Specification Limit;USL 系统抽样Systematic Sampling
组间变异Variation between Groups 总平均数Total Average
组内变异Variation within Group 干预Tempering
计量值Variable Data 良率Yield 总制程变异Total Process Variation
组中位数Subgroup Median 中心值Target 总变异Tota Variation
均匀分配Uniform Distribution 管制状态下Under Control 推移图Trend Chart
变异Variation 良率管制图Yield Control Chart
hekuofei (威望:0) (广东 东莞) 汽车制造相关 工程师
