求助,请帮忙看看这两句是啥意思啊,折磨了我许久
下面是客户对我们供应商管理的要求中的两项,看了许久还是不太明白是何意思,烦请各位大侠,帮帮忙,谢谢了!
s) If the supplier purchases products that include special assembly such as lead wire crimping assembly as an example, do you verify the assemb led parts for proper application and compatibility of assembled parts, and are assembly measurements monitored at incoming inspection?
t) If supplier purchases material for use as part of an assembled part, ex: electrical wire, does the supplier follow the customer's requirements for that material, ex. electrical wire specification from customer?
zhangxueli (威望:0) (江苏 扬州) 电子制造 工程师
谢谢,和我同事讨论的意思差不多,James7369,谢谢!
3 个回复,游客无法查看回复,更多功能请登录注册
