EINECS No Name/Group CAS No
200-061-5 D-glucitol C6H14O6 50-70-4
200-066-2 Ascorbic acid C6H8O6 50-81-7
200-075-1 Glucose C6H12O6 50-99-7
200-294-2 L-lysine C6H14N2O2 56-87-1
200-312-9 Palmitic acid, pure C16H32O2 57-10-3
200-313-4 Stearic acid, pure C18H36O2 57-11-4
200-334-9 Sucrose, pure C12H22O11 57-50-1
200-405-4 α-tocopheryl acetate C31H52O3 58-95-7
200-432-1 DL-methionine C5H11NO2S 59-51-8
200-711-8 D-mannitol C6H14O6 69-65-8
201-771-8 1-sorbose C6H12O6 87-79-6
204-007-1 Oleic acid, pure C18H34O2 112-80-1
204-664-4 Glycerol stearate, pure C21H42O4 123-94-4
204-696-9 Carbon dioxide CO2 124-38-9
205-278-9 Calcium pantothenate, D-form C9H17NO5.1/2Ca 137-08-6
205-582-1 Lauric acid, pure C12H24O2 143-07-7
205-590-5 Potassium oleate C18H34O2K 143-18-0
205-756-7 DL-phenylalanine C9H11NO2 150-30-1
208-407-7 Sodium gluconate C6H12O7.Na 527-07-1
212-490-5 Sodium stearate, pure C18H36O2.Na 822-16-2
215-279-6 Limestone
A noncombustible solid characteristic of sedimentary rock. It consists primarily of calcium carbonate 1317-65-3
215-665-4 Sorbitan oleate C24H44O6 1338-43-8
216-472-8 Calcium distearate, pure C18H36O2.1/2Ca 1592-23-0
231-147-0 Argon Ar 7440-37-1
231-153-3 Carbon C 7440-44-0
231-783-9 Nitrogen N2 7727-37-9
31-791-2 Water, distilled, conductivity or of similar purity H2O 7732-18-5
231-955-3 Graphite C 7782-42-5
232-273-9 Sunflower oil
Extractives and their physically modifiedderivatives. It consists primarily of the glycerides of the fatty acids linoleic, and oleic.(Helianthus annuus, Compositae). 8001-21-6
232-274-4 Soybean oil
Extractives and their physically modifiedderivatives. It consists primarily of the glycerides of the fatty acids linoleic, oleic, palmitic and stearic(Soja hispida, Leguminosae). 8001-22-7
232-276-5 Safflower oil
Extractives and their physically modifiedderivatives. It consists primarily of the glycerides of the fatty acid linoleic (Carthamus tinctorius, Compositae). 8001-23-8
232-278-6 Linseed oil
Extractives and their physically modifiedderivatives. It consists primarily of the glycerides of the fatty acids linoleic, linolenic and oleic(Linum usitatissimum, Linaceae). 8001-26-1
232-281-2 Corn oil
Extractives and their physically modifiedderivatives. It consists primarily of the glycerides of the fatty acids linoleic, oleic, palmitic and stearic.(Zea mays, Gramineae). 8001-30-7
232-293-8 Castor Oil
Extractives and their physically modifiedderivatives. It consists primarily of the glycerides of the fatty acid ricinoleic (Ricinus communis, Euphorbiaceae). 8001-79-4
232-299-0 Rape oil
Extractives and their physically modifiedderivatives. It consists primarily of the glycerides of the fatty acids erucic, linoleic and oleic(Brassica napus, Cruciferae). 8002-13-9
232-307-2 Lecithins
The complex combination of diglycerides of fatty acids linked to the choline ester of phosphoric acid. 8002-43-5
232-436-4 Syrups, hydrolyzed starch
A complex combination obtained by the hydrolysis of cornstarch by the action of acids or enzymes. It consists primarily of d-glucose, maltose and maltodextrins. 8029-43-4
232-442-7 Tallow, hydrogenated 8030-12-4
232-675-4 Dextrin 9004-53-9
232-679-6 Starch
High-polymeric carbohydrate material usually derived form cereal grains such as corn, wheat and sorghum, and from roots and tubers such aspotatoes and tapioca. Includes starch which has been pregelatinised by heating in the presence of water. 9005-25-8
232-940-4 Maltodextrin 9050-36-6
234-328-2 Vitamin A 11103-57-4
238-976-7 Sodium D-gluconate C6H12O7.xNa 14906-97-9
248-027-9 D-glucitol monostearate C24H48O7 26836-47-5
262-988-1 Fatty acids, coco, Me esters 61788-59-8
262-989-7 Fatty acids, tallow, Me esters 61788-61-2
263-060-9 Fatty acids, castor-oil 61789-44-4
263-129-3 Fatty acids, tallow 61790-37-2
265-995-8 Cellulose Pulp 65996-61-4
266-925-9 Fatty acids, C12-18
This substance is identified by SDA Substance Name: C12-C18 alkyl carboxylic acid and SDA Reporting Number: 16-005-00. 67701-01-3
266-928-5 Fatty acids C16-18
This substance is identified by SDA Substance Name: C16-C18 alkyl carboxylic acid and SDA Reporting Number: 19-005-00. 67701-03-5
266-929-0 Fatty acids, C8-18 and C18-unsaturated.
This substance is identified by SDA Substance Name: C8-C18 and C18 unsaturated alkyl carboxylic acid and SDA Reporting Number: 01-005-00. 67701-05-7
266-930-6 Fatty acids, C14-18 and C16-18-unsaturated.
This substance is identified by SDA Substance Name: C14-C18 and C16-C18 unsaturated alkyl carboxylic acid and SDA ReportingNumber: 04-005-00 67701-06-8
266-932-7 Fatty acids, C16-C18 and C18-unsaturated.
This substance is identified by SDA Substance Name: C16-C18 and C18 unsaturated alkyl carboxylic acid and SDA Reporting Number: 11-005-00 67701-08-0
266-948-4 Glycerides, C16-18 and C18-unsaturated.
This substance is identified by SDA SubstanceName: C16-C18 and C18 unsaturated trialkylglyceride and SDA Reporting Number: 11-001-00. 67701-30-8
267-007-0 Fatty acids, C14-18 and C16-18-unsaturated., Me esters
This substance is identified by SDA Substance Name: C14-C18 and C16-C18 unsaturated alkyl carboxylic acid methyl ester and SDA Reporting Number: 04-010-00. 67762-26-9
267-013-3 Fatty acids, C6-12
This substance is identified by SDA Substance Name: C6-C12 alkyl carboxylic acid and SDA Reporting Number: 13-005-00. 67762-36-1
268-099-5 Fatty acids, C14-22 and C16-22 unsaturated.
This substance is identified by SDA Substance Name: C14-C22 and C16-C22 unsaturated alkyl carboxylic acid and SDA ReportingNumber: 07-005-00 68002-85-7
268-616-4 Syrups, corn, dehydrated 68131-37-3
269-657-0 Fatty acids, soya 68308-53-2
269-658-6 Glycerides, tallow mono-, di- and tri-, hydrogenated 68308-54-3
270-298-7 Fatty acids, C14-22 68424-37-3
270-304-8 Fatty acids, linseed-oil 68424-45-3
270-312-1 Glycerides, C16-18 and C18-unsaturated. mono- and di-
This substance is identified by SDA SubstanceName: C16-C18 and C18 unsaturated alkyl andC16-C18 and C18 unsaturated dialkyl glyceride andSDA Reporting Number: 11-002-00. 68424-61-3
288-123-8 Glycerides, C10-18 85665-33-4
292-771-7 Fatty acids, C12-14 90990-10-6
292-776-4 Fatty acids, C12-18 and C18-unsaturated. 90990-15-1
296-916-5 Fatty acids, rape-oil, erucic acid-low 93165-31-2
6 个回复
benponytest (威望:0) (重庆 铜梁县) 咨询业 员工
1、放射性物质;
2、海关监管物资:海关监管目录上,不经处理、暂时存放在保税区或保税仓库再出口或过境物质;
3、不可分离中间体;同地使用和外运的可分离中间体
4、处于运输过程的危险物质和在危险配制品中的物质,危险品的运载工具;
5、不属于物质、配制品或物品:废料。
6、人用或兽用药品,进入或直接与人体接触的医用器具;
7、化妆品
8、食品添加、调味剂,食用香料;饲料添加剂;动物营养剂;
9、聚合物单体及其它化学物质:该单体或其它化学物质年生产或进口小于1吨;聚合物中游离未注册单体小于2%。
10、聚合物、配制品、商品(物品)本身不必注册。
11、REACH法规豁免附件包括的物质(附件IV物质附件V物质)。
12、用于产品与工艺研发(PPORD)的物质(5+5/10年);
13、再次进口且已经注册过的化学物质。
14、回收物质。
附件IV:根据第2条第7款(a)项对于注册义务的豁免
215-279-6 Limestone
232-281-2 Corn oil
232-299-0 Rape oil
232-307-2 Lecithins
232-679-6 Starch
附件V:根据第2条第7款(b)项对于注册义务的豁免
1.其他物质或物品暴露于如空气、湿气、微生物或阳光这样的环境因素时偶然发生的化学反应得到的物质。
2.由储存的另一种物质、配制品或物品偶然发生的化学反应产生的物质。
3.在其他物质、配制品和物品的最终使用中发生的化学反应中产生的而并非是制造商或进口商本身制造、进口或上市的物质。
4.并非以其本身制造、进口或投放市场并且源自下列情况引发的化学反应产生的某些物质:
(a)稳定剂、着色剂、调味剂、抗氧化剂、填充剂、溶剂、载体、表面活性剂、增塑剂、抗腐蚀剂、阻泡剂或消泡剂、分散剂、抑制沉淀剂、干燥剂、粘合剂、乳化剂、反乳化剂、脱水剂、胶凝剂、促黏剂、流动调节剂、pH值中和剂、阻隔剂、凝结剂、凝聚剂、阻燃剂、润滑剂、鳖合剂或品质控配制品,当以上物质按预期目的发挥作用时;或者
(b)一种物质仅具备某种特定的物理化学特性,当其按预期目的发挥作用时。
5.副产品,除非以其自身进口或上市。
6.某种物质与水结合形成的氢氧化物和水合离子,设若这种物质已由制造商或进口商应用本免责条款注册。
7.自然存在的下列物质,只要它们没有经过化学改性。
矿物质、矿石、精矿、水泥渣、天然气、液化石油气、天然气冷凝物、工业废气及其成分、原油、煤炭、焦炭等。
8.除第7条列举的种类之外,其他自然存在、未经化学改性的物质,除非它们满足据第67/548/EEC号指令的标准被分类为危险品。
9.氢、氧、惰性气体(氩、氦、氖、氙)、氮等危害和风险已经被充分了解的基本元素物质。
