CPK
求助!这组数据怎么分析CPK啊!
测得一组数据(公差是:-0.15/+0.15),上司说要做一下CPK分析,这组数据不从正态分布。用BOX-COX转换时说是数据必须大于0.所以想请教怎么分析CPK呢?
另外,如果用正态的方法分析了非正态的数据的话会造成什么后果呢?谢谢了!
-0.097222222
0.050420168
0.005484461
0.020092736
-0.069444444
-0.047619048
0.096892139
0.020092736
-0.097222222
-0.019607843
0.096892139
0.020092736
-0.138888889
-0.019607843
0.096892139
0.051004637
-0.138888889
-0.019607843
0.005484461
0.004636785
-0.137931034
-0.138888889
-0.005602241
0.060329068
-0.026275116
-0.137931034
-0.097222222
-0.019607843
0.096892139
-0.026275116
-0.137931034
-0.097222222
-0.019607843
0.096892139
0.004636785
-0.069444444
-0.019607843
0.096892139
0.004636785
0.042047532
-0.057187017
-0.166666667
-0.131652661
0.042047532
-0.041731066
0.042047532
-0.041731066
0.042047532
-0.041731066
-0.097222222
-0.047619048
0.023765996
-0.041731066
-0.027777778
-0.033613445
0.023765996
-0.026275116
-0.027777778
-0.019607843
0.023765996
0.020092736
-0.027777778
-0.033613445
0.023765996
-0.026275116
-0.027777778
-0.019607843
0.023765996
0.020092736
-0.097222222
-0.117647059
0.023765996
-0.026275116
-0.166666667
0.036414566
0.023765996
-0.041731066
0.069444444
0.050420168
0.042047532
-0.026275116
0.06442577
0.023765996
-0.026275116
0.06442577
0.042047532
-0.041731066
0.050420168
0.023765996
-0.026275116
0.06442577
0.023765996
-0.088098918
0.050420168
0.023765996
-0.088098918
-0.027777778
-0.005602241
0.042047532
-0.103554869
-0.005602241
0.042047532
-0.103554869
0.008403361
0.023765996
-0.088098918
0.023765996
-0.103554869
-0.111111111
-0.005602241
0.023765996
-0.103554869
0.023765996
-0.103554869
0.042047532
-0.103554869
0.050420168
0.023765996
-0.103554869
0
0.06442577
0.005484461
0.020092736
0
0.06442577
0.005484461
0.020092736
-0.166666667
0.008403361
0.060329068
-0.119010819
-0.166666667
0.008403361
0.060329068
-0.119010819
-0.166666667
0.008403361
0.060329068
-0.119010819
0
0.06442577
0.005484461
0.020092736
0
0.06442577
0.005484461
0.020092736
0
0.06442577
0.188299817
0.020092736
0
0.06442577
0.005484461
0.020092736
0
0.06442577
0.005484461
0.020092736
0
0.06442577
0.005484461
0.020092736
0
0.06442577
0.005484461
0.020092736
0.041666667
-0.033613445
0.023765996
0.020092736
0
0
-0.027777778
0.134453782
0.060329068
-0.103554869
0
0
-0.159663866
0.023765996
-0.072642968
0
-0.017241379
-0.013888889
0.060329068
-0.088098918
0
-0.019607843
0.042047532
-0.072642968
0
0
-0.152777778
0.008403361
0.060329068
-0.088098918
0
0
luoyuan73785 (威望:0) (四川 宜宾) 计算机相关 主管
你用什麼工具量的?小數位那麼多
2 个回复,游客无法查看回复,更多功能请登录注册
