有关于minitab的作业不会做,大哥大姐帮帮忙T T
我是在英国学会计,老师布置了作业要用minitab来做,并要写出分析的过程,是在是不会啊~~各位帮帮忙,给高分!
作业:You may undertake the analysis of one of the following three case studies:
(a) Sleep (Excel file SLEEP.xls, Minitab project file: SLEEP.MPJ)
(b) London (Minitab project file: LONDON.MPJ)
(c) Arbitrage Pricing Theory (Minitab project file: APT.MPJ)
The details are given in the respective files.
You are required to undertake a full regression analysis for one of the case studies from the above list. You will be assessed upon the submitted technical report. A viva may be conducted if it is felt necessary. You may use either Minitab and/or EViews for your analysis.
那个MPJ的我有,能教我的,留联系方式我给他转载请注明出自( 六西格玛品质网 http://www.6sq.net ),本贴地址:http://www.6sq.net/thread-271156-1-1.html
aaron_byd (威望:0) (广东 深圳) 电子制造 主管
2 个回复,游客无法查看回复,更多功能请登录注册
