A.BEX测试光盘的型号及测试项目
测试碟片的型号及用途
一、A.BEX TEST-CD
1、 TCD-710 Eccentric test CD(0+15/-0μm)
2、 TCD-710R Eccentric test CD(0+10/-0μm)with data sheet
3、 TCD-711 Eccentric test CD(70+/-15μm)
4、 TCD-711R Eccentric test CD(70+/-5μm)with data sheet
5、 TCD-712 Eccentric test CD(140+/-15μm)
6、 TCD-712R Eccentric test CD(140+/-5μm)with data sheet
7、 TCD-713 Eccentric test CD(210+/-15μm)
8、 TCD-713R Eccentric test CD(210+/-5μm)with data sheet
9、 TCD-714 Eccentric test CD(280+/-15μm)
10、TCD-714R Eccentric test CD(280+/-5μm)with data sheet
11、TCD-71RS Reference set dincludes(TCD-710R-714R)
12、TCD-721 Scratch test CD(0-2.0mm,0.4mm step)
13、TCD-721R Scratch test CD(0-3.0mm,0.2mm step)
14、TCD-7250B Defects test CD with channel 1K,-10dB sine wave(TCD-725A)
15、TCD-725A Defects test CD(interruption,black dots & fingerprints)
16、TCD-731RA Vertical debeation test CD(0.54-1.0mm)
17、TCD-732RA Vertical debeation test CD(0.43-1.0mm)
18、TCD-773 Unbalance test cd 1.0g.cm
19、TCD-774 Unbalance test cd 0.75g.cm
20、TCD-775 Unbalance test cd 0.5g.cm
21、TCD-776 Unbalance test cd 1.0g.cm
22、TCD-777 Unbalance test cd 0.75g.cm
23、TCD-778 Unbalance test cd 0.5g.cm
24、TCD-779 Unbalance test cd 0.3g.cm
25、TCD-781 Adjustment & checking of CD player
26、TCD-782 Adjustment & checking of CD player
27、TCD-783 Adjustment & checking of CD player
28、TCD-784 Adjustment & checking of CD player
29、TCD-785 Adjustment & checking of CD player
30、TCD-786 Adjustment & checking of CD player
31、TCD-792A Ageing CD(music CD for TCD-725A)
32、TCD-793 Ageing CD(music CD for TCD-732A)
33、TCD-794 Maximμm Data CD(80min)
34、TCD-795 Ageing CD(8cm)
二、A.BEX TEST CD-ROM
1、TCDR-701 Checking & Adjust 1.3m/second
2、TCDR-702 Checking & Adjust 1.3m/second
3、TCDR-703 Checking & Adjust 1.2m/second
三、A.BEX TEST VCD
1、 TCD-581A Standard test VCD with & NTSC version
2、 SVD-3047 Standard test VCD with black dots & fingerprints defects
3、 SVD-3048 Standard test VCD with Scratch defects
4、 SVD-3049 Eccentricity checking(0+/-5μm)
5、 SVD-3050 Eccentricity checking(70+/-5μm)
6、 SVD-3051 Eccentricity checking(140+/-5μm)
7、 SVD-3052 Eccentricity checking(210+/-5μm)
8、 SVD-3053 Eccentricity checking(280+/-5μm)
9、 SVD-3054 Vertical Deviation 1.0+/-5mm
10、TCD-772 Test Disc of RF Lenel 1 11/top 55%+5%/-10%
四、A.BEX TEST DVD
1、 PTD1-NOR DVD Normal test disc
2、 PTD2-ECC100 DVD test eccentricity disc 100+/-15mm(p-p)
3、 PTD4-ECC150 DVD test eccentricity disc 150+/-15mm(p-p)
4、 PTD4-DEF DVD test defect cisc(black band & fingerprints)
5、 PTD5-INT DVD test interruption disc
6、 SVD-3301 DVD test eccentricity disc 0+10/-0mm
7、 SVD-3302 DVD test eccentricity disc 50+/-5mm
8、 SVD-3303 DVD test eccentricity disc 100+/-5mm
9、 SVD-3304 DVD test eccentricity disc 150+/-5mm
10、SVD-3311 DVD test vertical deviation 0.4mm+/-0.05mm
11、SVD-3312 DVD test vertical deviation 0.6mm+/-0.05mm
12、SVD-3313 DVD test vertical deviation 1.0mm+/-0.05mm
13、SVD-3321 DVD test scratch disc 0.4-3.0mm(-0.2mm step)
14、TDV-520 DVD Normal test disc
15、TDV-510 DVD test eccentricity disc 0+10/-0mm
16、TDV-511 DVD test eccentricity disc 50+/-5mm
17、TDV-512 DVD test eccentricity disc 100+/-5mm
17、TDV-513 DVD test eccentricity disc 150+/-5mm
18、TDV-521 DVD test scratch disc 1.0-3.0mm
19、TDV-525 DVD test defect disc(black band & fingerprints)
20、TDV-531 DVD test vertical deviation 0.4mm+/-0.05mm
21、TDV-532 DVD test vertical deviation 0.6mm+/-0.05mm
22、TDV-533 DVD test vertical deviation 1.0mm+/-0.05mm
一、A.BEX TEST-CD
二、A.BEX TEST CD-ROM
三、A.BEX TEST VCD
四、A.BEX TEST DVD
qhtfyunfei (威望:19) (广东 深圳)
