谁能帮我解这张表格里运用MSA测试的情况(采用万用表收集的数据)
REPEATIBILITY AND REPRODUCIBILITY ANALYSIS REPORT
Date:2010 Aug., 08Upper spec limit:8.2000
Gage Identification:Vernier Caliper 06643737Lower spec limit:8.0000
Part Number:1S0429Nominal8.1000
Comments:8.20 / 8.00 〈2〉
Operator:XieqianghuaOperator:TangjieOperator:Hekeying
Trial 1Trial 2Trial 3RangeTrial 1Trial 2Trial 3RangeTrial 1Trial 2Trial 3Range
113.120013.140013.12000.020013.120013.140013.12000.020013.120013.130013.12000.0100
213.120013.120013.11000.010013.130013.120013.11000.020013.120013.130013.11000.0200
313.120013.120013.12000.000013.120013.130013.12000.010013.120013.120013.13000.0100
413.130013.120013.12000.010013.130013.120013.12000.010013.130013.120013.12000.0100
513.140013.140013.13000.010013.140013.140013.13000.010013.140013.140013.13000.0100
613.110013.130013.12000.020013.120013.130013.12000.010013.110013.130013.12000.0200
713.130013.120013.12000.010013.130013.120013.12000.010013.130013.120013.13000.0100
813.120013.120013.16000.040013.130013.120013.16000.040013.120013.130013.16000.0400
913.130013.130013.14000.010013.130013.130013.14000.010013.130013.130013.14000.0100
1013.130013.150013.16000.030013.130013.140013.16000.030013.130013.140013.15000.0200
X bar13.128X bar13.129X bar13.128333
R bar0.016R bar0.017R bar0.016
13.128
R barbar0.0163333X bar diff:0.001000# Trials23UCLR = R barbar x D413.129
D43.272.58UCLR:0.04214013.12833
Measurement Unit Analysis% Tolerance Analysis
Equipment VariationEquipment Variation
EV= (Rbarbar)x (K1)Trials23%EV= 100 x [ (EV) /
=0.016333x 3.05K14.563.05=100 x0.04982K3,"specs wrong",K3-K4))'>
0.049817= 24.9 %
Operators23
K23.652.7
Appraiser VariationAppraiser Variation
AV=sqrt(^2-)n = number samples%AV= 100 x [ (AV) /
((E25IF(K22="",G37,H37))^2),0,(((E25IF(K22="",G37,H37))^2)-(B35^2/(F42*IF(K22="",2,3)))))))'>0.0000000,10,IF(B18>0,9,IF(B17>0,8,IF(B16>0,7,IF(B15>0,6,IF(B14>0,5,IF(B13>0,4,IF(B12>0,3,"run more samples"))))))))'>n = 10=100 x0.000000K3,"specs wrong",K3-K4))'>
= .0 %
Repeatability and ReproducibilityRepeatability and Reproducibility
R&R= SQRT ((EV)^2+(AV)^2)R&R= SQRT ((%EV)^2+(%AV)^2)
= sqrt(0.049816667)^2+(0)^2= sqrt(24.90833333)^2+(0)^2
0.049817= 24.9 %
NOTES:
夏廷东007 (威望:0) (四川 成都) 汽车制造相关 员工 - 1
你好!你可以把原表格发到我邮箱zfxiatingdong@126.com 我看看给你回复!
2 个回复,游客无法查看回复,更多功能请登录注册
