请教几道黑带考试题
1.When σ=10, what sample size is need to specify a 95% confidence interval of ± units from the mean?
(A).7 (B). 11 (C). 32 (D).43
  1. A six sigma project to reduce billing statement expenses has shown the need to hire two additional mailroom clerks. Based on this information, which of the following metrics should be used to measure the finacial benfits of the project
(A). Cost of poor quality (B). Return on investment (C). Net present value (D). Internal rate of return
  1. A company's acount payable department is trying to reduce the time between receipt and payment of invoices. If the team has just complete a flowchart of the process and identified the critical steps, which of the following tools should be used next
(A). Fishbone diagram (B). Scatter diagram (C). Box and whisker plot (D), Histogram
上面三道题请高手帮忙做一下,并说明原因。跪谢!
reiden (威望:3) (江苏 无锡) 电气或能源 主管
第一道题,好像信息不全,要求计算n,但是置信区间的宽度不知道,那么n怎么算也就不知道?(如果知道置信区间宽度,则根据公式mean+/-Z(1-a/2) σ/sqrt(n) 即有21.96*σ/sqrt(n)=置信区间宽度,可以求出n)
第二道题,应该是投资回报吧(Return on investment )
第三道题,流程图画出来之后,应该是寻找可能的因子,所以用鱼骨图(Fishbone diagram)
4 个回复,游客无法查看回复,更多功能请登录注册
