焊接专业英语词汇(热喷涂与热切割)
热喷涂 thermal spraying
火焰喷涂 flame spraying
电弧喷涂 electric arc spraying
等离子喷涂 plasma spraying
高频感应喷涂 high frequency spraying
金属喷涂 metal spraying; metallizing
塑料喷涂 plastic spraying
陶瓷喷涂 ceramic spraying
喷熔 spray-fusing
表面粗糙化处理 surface roughening
电火花拉毛 electrospark roughening
抛锚效应 anchoring
喷涂层 spray-fused coating
喷熔层 spray-fused coating
结合层 bond coating; under coating
工作层 work coating
结合强度 adhesive strength
涂层强度 strength of coating
封孔处理 sealing
封孔剂 sealant
喷涂率 spray rate
沉积效率 deposition efficiency
孔隙率 porosity
喷涂材料 spraying material
自熔剂合金粉末 self-fluxing alloy powder
喷炬(枪)spray torch;
2. 热切割
热切割 thermal cutting (TC)
气割 gas cutting; oxygen cutting
氧溶剂切割 powder cutting
氧-石英砂切割 quartz powder cutting
电弧切割 arc cutting
氧气电弧切割 oxy-arc cutting
空气电弧切割 air arc cutting
等离子弧切割 plasma arc cutting (PAC)
空气等离子弧切割 air plasma arc cutting
氧等离子切割 oxygen plasma arc cutting
水再压缩空气等离子弧切割 air plasma water injection arc cutting
双层气流等离子弧切割 dual gas plasma arc cutting; shielded gas plasma arc cutting
激光切割 laser cutting(LC); laser beam cutting
电子束切割 electron beam cutting
喷气激光切割 gas jet laser cutting
碳弧切割 carbon arc cutting
水下切割 underwater cutting
喷水式水下电弧切割 waterjet method underwater arc cutting
氧矛切割 oxygen lancing; oxygen lance cutting
溶剂氧切割 powder lancing
手工气割 manual oxygen cutting
自动气割 automatic oxygen cutting
仿形切割 shape cutting
数控切割 NC (numerical-control) cutting
快速切割 high-speed cutting
垂直切割 square cut
叠板切割 stack cutting
坡口切割 beveling; bevel cutting
碳弧气割 carbon arc air gouging
火焰气刨 flame gouging
火焰表面清理 scarfing
氧熔剂表面修整powder washing
预热火焰preheat flame
预热氧preheat oxygen
切割氧cutting oxygen/ cutting stream
切割速度cutting speed
切割线lone of cut/ cut line
切割面face of cut/ cut face
切口kerf
切口上缘cutting shoulder
切口宽度kerf width
后拖量drag
切割面平面度evenness of cutting surface/ planeness of cutting surface
割纹深度depth of cutting veins/ stria depth
切割面质量quality of cut face
上缘熔化度shoulder meltability/ melting degree of shoulder
切口角kerf angle
缺口notch
挂渣adhering slag
结瘤dross
割炬cutting torch/ cutting blowpipe/ oxygen-fuel gas cutting torch
割枪cutting gun
割嘴cutting nozzle/ cutting tip
快速割嘴divergent nozzle/ high-speed nozzle
表面割炬gouging blowpipe
水下割炬under-water cutting blowpipe
水下割条electrode for under-water cutting
粉剂罐powder dispenser
数控切割机NC cutting machine
门式切割机flame planer
光电跟踪切割机photo-electric tracing cutting
火焰切管机pipe flame cutting machine
磁轮式气割机gas cutting machine with magnetic wheels
火焰喷涂 flame spraying
喷熔 spray-fusing
抛锚效应 anchoring
工作层 work coating
封孔处理 sealing
封孔剂 sealant
喷涂率 spray rate
孔隙率 porosity
喷炬(枪)spray torch;
2. 热切割
电弧切割 arc cutting
仿形切割 shape cutting
垂直切割 square cut
叠板切割 stack cutting
火焰气刨 flame gouging
火焰表面清理 scarfing
预热火焰preheat flame
预热氧preheat oxygen
切割速度cutting speed
切口kerf
切口宽度kerf width
后拖量drag
切口角kerf angle
缺口notch
挂渣adhering slag
结瘤dross
割枪cutting gun
粉剂罐powder dispenser
门式切割机flame planer
0 个回复
