【翻译】第四十八篇 The Pros of Proactive Product Servicing
你好,我是小编H。请对以下文章有翻译兴趣的组员留下你的预计完成时间,并发短信息联系小编H,以便小编登记翻译者信息以及文章最终完成时的奖惩工作。感谢支持翻译组!
ThePros of Proactive Product Servicing
Monitoringmaintenance helps avoid unexpected shutdowns
By Necip Doganaksoy, Gerald J. Hahn and William Q. Meeker
Just as athletescan experience an injury that takes them out of a game, systems can experiencecomponent failures that require downtime and repair.
We will describe three approaches1 that canminimize the cost, inconvenience or potential danger of field failures throughstatistically based proactive servicing (or just-in-time maintenance).
A prime goal ofproactive product servicing is to avoid unscheduled shutdowns. It is usuallymuch less disruptive and costly to perform repairs during scheduled maintenanceon automobiles, aircraft engines, locomotives and medical scanners, forexample, than it is to deal with unexpected failures in the field.
The emergence oflong-term service agreements—manufacturers selling not just products, but alsoguaranteed ongoing levels of service to customers—has further encouragedproactive servicing and increased manufacturers’ desire to build highreliability into design in the first place.
Even when ashutdown cannot be prevented, proactive servicing is still useful to ensurespeedy, inexpensive repair, which can reduce the deleterious impact of suchshutdowns.
The threeapproaches for proactive product servicing are:
http://www.asq.org/img/qp/082224_table1.gif
Thus, when anoil pressure drop is indicated, we need to find the reason so we can take theappropriate action. Sensor data on how oil pressure—and oil and watertemperature—are changing over time can help make this determination.
Data acquisition: Each of the three measured oil pressure drop modes shown inTable 1 were induced in a lab test to observe the resulting sensormeasurements. Figure 1 shows the readings on three sensors—monitoring oilpressure, oil temperature and water temperature—over a 30-second time period.The solid triangle marks the point at which the problem was induced, asevidenced by an appreciable change in one or more of the three measurements.
Analysis: Each of the three incidents resulted in a sudden, sharp dropin the reading for oil pressure. The accompanying changes in oil temperatureand water temperature readings, however, differed. Thus, data from the threesensors might help distinguish among the three possible reasons for theapparent oil pressure drop:
Results in exampleThe resultingpatterns were sufficiently distinct and similar to those depicted in Figure 1to develop a useful algorithm for the three sensor (and some further)measurements to identify the reason for a drop in the measured oil pressure.This led, in a great majority of cases, to appropriate remedial action,including the all-important decision of whether or not to shut down the system.
The analyses required the use of advancedmultivariate5 and time series6 methods. Variousother analytic methods are also used in automated monitoring for impendingfailures, including machine learning, neural nets and Bayesian belief networks.7, 8
Statisticalmethods play an important part in proactive product servicing. Such work, asalways, is conducted in collaboration with knowledgeable engineers and subjectmatter experts.
Necip Doganaksoyis astatistician and Six Sigma Master Black Belt at the GE Global Research Centerin Schenectady, NY. He has a doctorate in administrative and engineeringsystems from Union College in Schenectady. Doganaksoy is a fellow of ASQ andthe American Statistical Association.
Gerald J. Hahn is a retired manager of statistics at the GE Global ResearchCenter in Schenectady, NY. He has a doctorate in statistics and operationsresearch from Rensselaer Polytechnic Institute in Troy, NY. Hahn is a fellow ofASQ and the American Statistical Association.
William Q. Meeker is professor of statistics and distinguished professor ofliberal arts and sciences at Iowa State University in Ames, IA. He has adoctorate in administrative and engineering systems from Union College inSchenectady, NY. Meeker is a fellow of ASQ and the American StatisticalAssociation.
- Optimum product maintenance scheduling.2. Proactive parts replacement.3. Automated monitoring for impendingfailures.
- For the faulty sensor, the drop in the oilpressure reading was not accompanied by any discernible change in either oil orwater temperature.2. For the cooling system failure, a sharprise in water temperature preceded the drop in measured oil pressure, which wasalso accompanied by a sharp rise in oil temperature.3. For the oil pump failure, a sharp rise inoil temperature followed the drop in measured oil pressure. Water temperatureremained unchanged.
5 个回复
dhjulia (威望:0) (江苏 苏州) 机械制造 工程师
