求一个20样本的 计数型MSA 大样本法 统计表格
我手上有一份50个样件的大样MSA分析表格,但是需要一个20个样件的MSA分析表格
BTW: 求问高手。
在用minitab统计计数型MSA的时候。
使用“属性一致性分析”数据后
评估不一致
检验员 # 1 / 0 百分比 # 0 / 1 百分比 # 混合 百分比
1 0 0.00 0 0.00 3 6.00
2 0 0.00 0 0.00 5 10.00
3 0 0.00 0 0.00 5 10.00
# 1 / 0: 多个试验中误将标准 = 0 者一致评估为 = 1 的次数
# 0 / 1: 多个试验中误将标准 = 1 者一致评估为 = 0 的次数
# 混合: 多个试验中所有的评估与标准不相同者。
明明数据中有漏判和误判,为什么MINITAB的数据不显示呢。混合数是正确的。
(我使用的数据为3实验员检测3次,对50个样本)
EMAIL: benimaru77@qq.com
数据是这样的:
零件编号 A-1 A-2 A-3 B-1 B-2 B-3 C-1 C-2 C-3 基准
1 pass pass pass pass pass pass pass fail pass pass
2 pass pass pass pass pass pass pass pass pass pass
3 pass pass pass pass pass pass pass pass pass pass
4 fail fail fail fail fail fail fail fail fail fail
5 pass pass pass pass pass pass pass pass pass pass
6 pass pass pass pass pass pass pass pass pass pass
7 pass fail pass pass pass pass pass pass pass pass
8 pass pass pass pass pass pass pass pass pass pass
9 pass pass pass pass pass pass fail pass pass pass
10 pass pass pass pass pass pass pass pass pass pass
11 pass pass pass pass fail pass pass pass pass pass
12 pass pass pass pass fail pass pass fail pass pass
13 pass pass pass pass pass pass pass pass pass pass
14 pass pass pass pass pass pass pass pass pass pass
15 fail fail fail fail fail fail fail fail fail fail
16 pass pass pass pass pass pass pass pass pass pass
17 pass pass pass pass pass pass pass pass pass pass
18 pass pass pass pass pass pass pass pass pass pass
19 pass pass pass pass pass pass pass pass pass pass
20 pass pass pass pass pass pass pass pass pass pass
21 pass pass pass pass pass pass pass pass pass pass
22 pass pass pass pass pass pass pass pass pass pass
23 fail pass pass pass pass pass pass pass pass pass
24 pass pass pass pass pass pass pass pass pass pass
25 pass pass pass pass pass pass pass pass pass pass
26 fail fail fail fail fail fail fail fail fail fail
27 pass pass pass pass pass pass pass pass pass pass
28 pass pass pass pass pass pass pass pass pass pass
29 pass pass pass pass pass pass pass pass pass pass
30 pass pass pass fail pass pass pass pass pass pass
31 pass pass pass pass pass pass pass pass pass pass
32 pass pass pass pass pass pass pass pass pass pass
33 pass pass pass pass pass pass pass pass pass pass
34 pass pass pass pass pass pass pass pass pass pass
35 pass pass pass pass pass pass pass pass pass pass
36 fail fail fail fail fail fail fail fail fail fail
37 pass pass pass pass pass pass pass pass pass pass
38 pass pass pass pass pass pass pass pass pass pass
39 pass pass pass pass pass pass pass pass pass pass
40 pass pass pass pass fail pass pass pass pass pass
41 pass pass pass pass pass pass fail pass pass pass
42 pass pass pass pass pass pass pass pass pass pass
43 pass pass pass pass pass pass pass pass pass pass
44 pass pass pass pass fail pass pass pass pass pass
45 pass pass pass pass pass pass pass pass pass pass
46 fail fail fail fail fail fail fail fail fail fail
47 pass pass pass pass pass pass pass pass pass pass
48 pass fail pass pass pass pass pass pass pass pass
49 pass pass pass pass pass pass pass pass pass pass
50 pass pass pass pass pass pass fail pass pass pass
BTW: 求问高手。
使用“属性一致性分析”数据后
评估不一致
数据是这样的:
4 个回复
benimaru77 (威望:0) (江苏 南京) 机械制造 员工
当一测试员判定3次。3次都判定错误的情况下才在评估不一致中有数据体现
但Excle的大样法MSA表格中似乎跟此判定不太一致。
求解。。。
