可靠性标准都是干什么的?
小弟初来乍道!
想问问这些都是什么要求啊啊?有没有对应的标准?
FMEA result of each product related/每个相关产品的FMEA的结果
a. IEC 60721-3-3:”Classification of environmental conditions-part 3-3:Classification of groups.
b. IEC 60068-2-27: “Environmental testing. Part 2-27: Tests Ea and guidance Shock”
c. IEC 60721-2-6: “Classification of environmental conditions. Part 2: “Environmental conditions appearing in nature. Vibration and shock”
d. IEC 60068-3-3: “Environmental testing – part 3: Guidance. Seismic test methods for equipment
e. ETSI EN 300 019-2-3: “Environmental Engineering (EE); Environmental conditions and environmental tests for telecommunications equipment; Part 2-3: Specification of environmental tests; Stationary use at weather protected locations”
f. JESD22 B103 – JEDEC STANDARD : Vibration, variable Frequency/JESD22 B103 - JEDEC标准:振动,变频
g. JESD22 B104C – JEDEC STANDARD : Mechanical Shock/JESD22 B104C - JEDEC标准:机械冲击
h. JESD22 A104 – JEDEC STANDARD : Temperature cycling
- Sample testing and result on/抽验结果
zhx1428 (威望:0) (江苏 常州) 其它行业 工程师
