Minitab 16.2.1 发布
Minitab 16.2.1 发布
可从如下地址下载:
http://fs1.minitab.com/prodins ... u.exe
多语言包下载:
http://fs1.minitab.com/prodins ... p.exe
特别文件及解决方法(不用多解释了)
http://bbs.pinggu.org/thread-1321773-1-1.html
Part 1. New Features in Minitab 16.2
Part 2. Problems Resolved in Minitab 16.2.1
Several specific issues have been resolved in Minitab 16.2.1, including:
Item 1
When selecting "Snapshot" In Assistant > Capability Analysis > Capability Analysis, a run-time error may occur after populating the dialog box and clicking OK. (166541)
Item 2
When you save a project in Minitab 16.1.0 or 16.1.1 that contains certain charts, Minitab 16.2.0 may fail to re-create these charts accurately when it opens that project file; or Minitab 16.2.0 may display assertion failure errors, or may lock up completely, when you attempt to access or edit these charts. Minitab 16.2.1 opens charts from all previous versions of Minitab 16 without error. The charts in question are: any control chart from the Assistant, Type 1 Gage Study, Tsquared Chart, Tsquared-Generalized Variance Chart, and CUSUM Chart. (166535)
Item 3
Histograms with cut points may fail to include all data in the column. (166488)
Item 4
With certain hardware configurations, running the Response Trace Plot in Minitab's Mixtures Design of Experiment causes the user's computer to lock up. (164625)
Minitab 16.2.1 发布
可从如下地址下载:
多语言包下载:
特别文件及解决方法(不用多解释了)
- G and T Charts – Monitor time or opportunities between rare events with these control charts.
- Laney P’ and U’ Charts – Create control charts for attribute data when P and U charts are not effective due to overdispersion or underdispersion. Diagnostic tools are also provided to determine when Laney charts are more appropriate than P and U charts.
- Nelson Estimate Method – Individuals and I-MR charts include this additional method for estimating the standard deviation.
- Improved Assistant Gage R&R Output – The Variation Report includes both the Operator and Operator*Part interaction for the Reproducibility component.
Item 1
Item 2
Item 3
Item 4
30 个回复
codan (威望:0) (河北 保定) 汽车制造相关 员工
